Leak help / torque specs
Old Feb 10, 2020 | 09:37 PM
bfleischer's Avatar
bfleischer
Thanks guys . They were finger loose but I'm doubting tightening will fix my problem. Maybe I'll get lucky.
Old Feb 14, 2020 | 11:52 AM
bfleischer's Avatar
bfleischer
So
Confirmed leak is definitely coming from the cass seam.
Has anyone had any luck with 3m or ultra grey black ? I know I have to clean the area really well and I was going to use a dremel and lightly go over the seam and then do a light bead down the length of case.
Any other suggestions or ideas
Old Feb 14, 2020 | 10:36 PM
TXCHOP's Avatar
TXCHOP
Havent heard of that working too well. worth a shot i guess as the other way is to pull the complete motor down to inspect and correct. I see your cases were powdercoated. Did you assemble yourself? Was they overspray on the seams?
Old Feb 15, 2020 | 01:00 PM
bfleischer's Avatar
bfleischer
A local shop did the motor work but they are no longer around. No over spray visible on the seams.
I'll give it a shot and see what happens. Either loctite 518 or 3m grey is what I'm considering trying.
Thanks
leafman60
Feb 15, 2020 12:27 PM
SCHOONER
Feb 27, 2013 05:47 PM
stevemaman
Exhaust System Topics
Jun 19, 2012 09:10 PM
RanD
Apr 18, 2007 06:52 PM
Littleshack
Mar 15, 2007 04:53 PM
