Pistons arrows
Old Jan 29, 2023 | 06:32 AM
FXWG'80's Avatar
FXWG'80
Default Pistons arrows
I know, so much has already been said and written, but I didn't find "my" right answer.
On the head of my pistons is an arrow opposed to an X. see photo
I've read that the HD pistons in the shovelheads have the arrow pointing in the direction of travel, forward
Aftermarkets the arrows both go towards the exhausts. So in the first cylinder it remains in the same position, forward, and in the rear cylinder it turns towards the exhaust
It's correct?
Help me.
I found this logo W, inside the piston with code 4293.
It's a WISECO? see photo
Thanks to anyone who can help me
Old Jan 29, 2023 | 07:47 AM
pgreer's Avatar
pgreer
On the domed pistons for Shovelhead engines, you should notice that one valve relief in the top of the piston is larger than the other. The larger relief goes with the larger intake valve.
Paul
Old Jan 29, 2023 | 10:51 AM
FXWG'80's Avatar
FXWG'80
I'll check again but haven't seen a difference
Old Jan 29, 2023 | 11:06 AM
jbarr1's Avatar
jbarr1
https://powersports.wiseco.com/media...ShovelHead.pdf
Old Jan 29, 2023 | 02:12 PM
FXWG'80's Avatar
FXWG'80
but my problem and that I'm not sure are Wiseco
Old Jan 29, 2023 | 02:13 PM
FXWG'80's Avatar
FXWG'80
Paul
two completely identical faces
Old Jan 29, 2023 | 05:51 PM
jbarr1's Avatar
jbarr1
The Wiseco 4293 is a shovelhead series piston. Why don’t you think that’s what you have?
Old Jan 30, 2023 | 04:27 AM
FXWG'80's Avatar
FXWG'80
I didn't know it was stock on shovelhead.
I thought the previous owner had changed them given the +0.010.....
Old Jan 30, 2023 | 04:30 AM
FXWG'80's Avatar
FXWG'80
Now I just need to figure out the "arrow" and the "X" as the faces on the piston are identical
Old Jan 30, 2023 | 05:25 AM
gravybiscuit's Avatar
gravybiscuit
Default Installation Instructions for Wiseco 1340 Shovelhead PDF File
Harley1340ShovelHead.pdf
FC 7.5.1-17 Rev. (P153) (wiseco.com)
File Type: pdf
