Problem with timing an Evo
Old Mar 7, 2023 | 01:48 PM
  #31
nutsandbolts5212's Avatar
nutsandbolts5212
You'll have to take it apart. It might have mucked up the valve seal and could possibly have caused the valve to sick.. Don't know for sure...
Call larry or text him a pic..
I just did, waiting for a response. I'll take some more photos when I get it apart.
Ride safe!!
Old Mar 7, 2023 | 01:52 PM
  #32
wfolarry's Avatar
wfolarry
It looks like the condom to me too. Strange.
Bring the head over & it's a quick fix.
Old Mar 7, 2023 | 02:39 PM
  #33
nutsandbolts5212
Here are some photos
Ride safe!
Old Mar 7, 2023 | 03:11 PM
  #34
nutsandbolts5212
Here we go
Ride safe!
Old Mar 7, 2023 | 03:20 PM
  #35
Max Headflow's Avatar
Max Headflow
Looking at the head gasket seat on the surface of the head, you weren't doing something like putting O rings on the head to cylinder dowels?
Your cylinder studs look back asswards also...
Old Mar 7, 2023 | 03:26 PM
  #36
Max Headflow
Marks from the HG seem to disappear near the dowel.. That other mark near the dowel is curious..
Old Mar 7, 2023 | 04:52 PM
  #37
nutsandbolts5212
What do you mean by the cylinder studs looking back asswards? They are the originals. Only used the cometic gasket for the head gasket, no o-rings.
That curious looking stuff was some white powder residue, not sure about that. It wiped right off.
Ride safe!
Old Mar 7, 2023 | 05:00 PM
  #38
nutsandbolts5212
Ok, all cleaned up and going back together. Any suggestions before I start??
Ride safe!
Old Mar 7, 2023 | 05:23 PM
  #39
Hey Man's Avatar
Hey Man
Originally Posted by nutsandbolts5212
Hey guys, I'm trying to set the timing correctly on this Evo. I have installed a Dynatek S ignition and after following the timing set up instructions provided the bike is still running rough. I have an S&S E carb with an initial basic set up done per S&S. When the bike is running I can hear the timing is off, some white smoke from the exhaust, and when I close the choke she sputters and dies. This is the first start or starts on a complete motor rebuild. Can the timing be adjusted while the motor is running?
Any advice appreciated and thanks in advance?
Ride safe!
Your slow jet might be plugged.
Here are the plugs and I'm running rich. Took a camera down the front spark plug hole and have what appears to be a gas/oil mix on top of the piston. The rear is fine.
Ride safe!
Most likely from running it too long with the enrichener on.
Also, the carb was set up per S&S basic set up proceedures.
Ride safe!
Turn off your accelerator pump before making carb adjustments.
Old Mar 7, 2023 | 06:19 PM
  #40
nutsandbolts5212
Brand spanking new carb and checked them just in case, all good on the jets.
Yes that's what others said too. Thanks
Yes I will and thanks again.
Ride safe!
