Left over part
Old Jun 24, 2023 | 01:53 PM
Jim-Bob's Avatar
Jim-Bob
2nd Gear
Barneyboy, it IS a lot like that except for the knurl. Even rounded off at the edge like your tool. I have a magnet on a stick but it's old school, about 3/8" OD with no focus ring.
Motojockey, I thought #19 or #20 might be in the running. ( Number19 has to go in from the starter side, despite the picture) Maybe 20 as it shows to be in the outer cover, which I did pull to change the gasket. But both are shown in the Harley manual as being split bushings. IF the HD book was wrong, & IF it was loose in the outer cover bore, it could be the animal.
I'm going to measure the bushing / spacer & see if it might belong in the cover. I sure don't want to pull the cover if I don't have to. (New James gaskets & Amsoil synthetic oil!)
Thanks to all who've taken the time to weigh in on this so far.
Old Jun 24, 2023 | 05:32 PM
djl's Avatar
djl
Not a fan of James gaskets, always Cometic or lately CYCO which I have reused several times. Don't know if that is possible with James but maybe.
Old Jun 24, 2023 | 08:09 PM
Jim-Bob's Avatar
Jim-Bob
2nd Gear
Dimensions on this "bushing / spacer":
.400" deep 10.0 mm
.705" OD 17.91 mm
.590: ID 14.91 mm
Jim
Old Jun 24, 2023 | 08:21 PM
MotoJockey's Avatar
MotoJockey
Those dimensions are WAY too big for part #20.......
Old Jun 25, 2023 | 10:25 AM
barneyboy's Avatar
barneyboy
.400" deep 10.0 mm
.705" OD 17.91 mm
.590: ID 14.91 mm
Jim
Below are the dimensions from a few different aftermarket suppliers.
Old Jun 25, 2023 | 08:02 PM
Since 1968's Avatar
Since 1968
Thinking back, did you ever have such a part go missing on a previous job? Maybe it's been laying in some nook or cranny for years, just waiting to get its revenge for being abandoned. I had this happen with a small bolt once, drove me nuts until I remembered having to replace a lost one about a year earlier....
Old Jun 26, 2023 | 07:46 AM
Jim-Bob's Avatar
Jim-Bob
2nd Gear
That's good info, Since 1968. I did some snooping over the weekend & found just as you did, that the bushing is "close, but no cigar" in size,, too big. Plus, it is a solid part where both 19 & 20 are split bushings.
As for could it be an orphan: I don't THINK so as my bike shed is brand new last fall, having been built to get the horses out of the carport & protected over the winters.
But that's not to say the part couldn't have come from a tool bag or similar newly introduced source.
But with y'all's help, I'm pretty sure it wasn't left out of the bike when I put it back together. Thanks!
Old Jun 26, 2023 | 09:33 AM
MotoJockey's Avatar
MotoJockey
Good info Barney....... I thought part #20 was the dowel type bushing to help hold the gasket in place. I forgot about the bushing in the outer primary case for the starter shaft.
Dennyh
2018+ Softail Models
15
Nov 22, 2019 04:44 AM
1982DSB
Dyna Parts
Jan 29, 2019 02:10 PM
wmnmy
Panhead
Jul 29, 2018 05:46 AM
EvilWayz
Ironhead
Aug 9, 2010 09:25 PM
