Cams are shot
Old Jul 30, 2023 | 10:44 PM
Vince Brawner's Avatar
Vince Brawner
Default Cams are shot
So today i was changing the cam chain tensioners on my Road King and discovered my my cams are scored and pitted. They are the SEH203 cams. I'm at a loss now because they need replaced but I want to bump to the next size up without changing springs. I'm looking at the S&S 509 or the Wood TW6. Interested in what other's thoughts are on the matter.
Old Jul 31, 2023 | 10:21 AM
bustert's Avatar
bustert
pictures and mileage will help
hd cams are not the greatest in craftsmanship but the wear could be normal and not hurting a thing.
Old Jul 31, 2023 | 10:40 AM
FLASH1970's Avatar
FLASH1970
ive has SE204's on my 01 with stock springs for about 25k miles...
Old Jul 31, 2023 | 10:42 AM
springers4ever's Avatar
springers4ever
Cool Lifters too ...
If you feel the cams are bad ...better check out the lifters too ...that would be the cause of the cam failure ...
Old Jul 31, 2023 | 01:19 PM
tdrglide's Avatar
tdrglide
Most likely not enough compression for the 6. The 509 might be a good fit. However, being it's a MM fuel injection system, how are you going to tune it? Getting hard to find tuners who will touch them nowadays. Options start getting expensive. Cam swap to different not exactly plug and play.
By the way, if replacing cams, also replace lifters. Also inner cam bearings if they were not already replaced with full complement type bearings.
Old Jul 31, 2023 | 02:39 PM
Vince Brawner
its a 2001 with 35k and some change. I'll take some pics tonight. The reason I don't want to put them back is the pitting. The light scuffing seemed normal but the pitting bugged me. I think whoever put it together forgot the lube.
Old Jul 31, 2023 | 02:43 PM
Vince Brawner
I understand it's not plug and play that's why I a'm looking at similar profiles. I'm really just interested in having the torque peak a little earlier. I'm new to the FI engines so that's why I'm looking for advice. There is a place a couple towns away that will still tune it.
Old Jul 31, 2023 | 03:09 PM
Uncle Larry's Avatar
Uncle Larry
I have a good used set of SE-204's ... Let me know
Old Jul 31, 2023 | 05:13 PM
tdrglide's Avatar
tdrglide
Okay then, I would be looking at the S&S 509. Or maybe Andrews 21. As has been said, for the Wood 6, you will need a lot more compression than you now have. - Meaning head work or pistons or both. Otherwise it would be softer off the bottom than you have now. A Woods 6 and a S&S 509 are WAY different cams.
Call those tuners up and ask their opinion. If one says Woods 6 in a basically stock 88", find another tuner. Either that or spend a lot of time above 4,000 rpms
Old Jul 31, 2023 | 06:01 PM
djl's Avatar
djl
+1 on the 509; maybe the best bolt in for the TC88. New lifters, Johnson Hy-Lifts from WFO Larry; Toyo/Torrington B148 inner cam bearings also a good idea.
