Keeping Engine Temperature down
Old Feb 2, 2024 | 02:22 AM
OakMountainRider's Avatar
OakMountainRider
Originally Posted by OakMountainRider
Yes, I run at 13 AFR at idle and a bit up, just for this reason. Also the EITMS starts adding fuel at 262 F, which is really good. However, I feel it is not enough after installing the big bore and I am thinking about a fan assisted oil cooler or just a fan.
I need to correct myself: The EITMS starts adding fuel at 297° F. Sorry about that.
Old Feb 2, 2024 | 06:49 AM
Fat11Lo's Avatar
Fat11Lo
Originally Posted by djl
I don't completely understand the drama between the Love Jugs guys and Jason but knowing Jason and always rooting for the underdog, I come down on Jason's side and will never buy the Love Jugs product. Seems to me that the market for cooling fans for Harleys is big enough for both; let the buyer decide which product he/she wants. I do run an HD oil cooler that mounts between the down tubes and, so far it has been enough. If I ever need fan asssist, I will probably try the LaNale product.
I felt the same way after following his thread but in the end I bit the bullet and decided I had to protect my investment, wish it would have turned ot better for him
Old Feb 2, 2024 | 06:53 AM
Fat11Lo's Avatar
Fat11Lo
Oak Mountain Rider, did you ever get the bike tuned? Timing will effect heat as well as fuel
Old Feb 2, 2024 | 07:47 AM
OakMountainRider
Yes, I believe it is rather well tuned, at last.
1/ Tune from Dynojet for Dyna 2006 with Andrews 26
2/ Last summer, and after big bore to 98 ci, I took the bike to a local tuner and got new VE-tables
3/ Then I autotuned these VE:s 3-4 times and pulled the spark advance 18 %
I tried different timings, like -12, -18, -24, -30, -36, -42 and -48 % just to see what happened. Finally I found the spot where the bike ran smooth. I feel this timing correlates well with the AFR which is set to 13:1 (idle) 14.2:1 (cruising).
Hoping to make things even more accurate, I will go with Target Tune this spring.
Old Feb 2, 2024 | 07:48 AM
Rounders's Avatar
Rounders
If I had to do it again maybe I would consider jaggs coolers on the down tubes. The harley coolers in front of volt reg are PIA when you want to do many things.
Old Feb 2, 2024 | 08:31 AM
OakMountainRider
x
Old Feb 2, 2024 | 08:32 AM
djl's Avatar
djl
I felt the same way after following his thread but in the end I bit the bullet and decided I had to protect my investment, wish it would have turned ot better for him.
Well, you gotta do what you gotta do but no Love Jugs are in my future. I am glad to see that you are still interacting with me.
Old Feb 2, 2024 | 08:46 AM
OakMountainRider
Am thinking about Jagg oil cooler with fan or Ultra Cooler with fan. Also considering Jim´s Airflow or the Love Jugs. Wards I cannot find where to buy.
Old Feb 2, 2024 | 10:31 AM
tdrglide's Avatar
tdrglide
Same here. At least blacked out their logo.
I just use the fans manual on/off switch. Turn on when I feel needed. Or go find some AC and a cold one
Old Feb 2, 2024 | 02:11 PM
djl's Avatar
djl
You won't find Wards; Love Jugs pretty much put Jason out of business. Like I said in my previous, I don't know the back story, if there is one, but that's the way I see it. Take a look at the LaNale unit; no personal experience but if I needed fan assist, I would try it out.
