Low power
Old Feb 9, 2024 | 11:28 PM
tdrglide's Avatar
tdrglide
I would want to flush out cam chest and crankcase as best as possible before reassembly. Including oil lines, oil cooler. Replace cam plate. Crud is probably still in there. Pull plug at bottom of crankcase and drain oil. Debris that went through the pump is still in motor and maybe oil pan. Clean as much as you can.
Old Feb 10, 2024 | 12:58 AM
60Gunner's Avatar
60Gunner
Exactly. I wouldn't stop at draining the crankcase, tho. A good flush and blowing out oil passages, etc. Same with the oil tank. Basically a complete tear down is in order imo..
ilikeharleys
Jul 3, 2014 07:57 PM
Camo King
Aug 6, 2010 07:56 AM
cornstalk
Jun 27, 2010 03:11 AM
schigur
Shovelhead
Jun 19, 2008 02:32 PM
wydopn231
Feb 29, 2008 07:39 PM
