Head porting
Old Feb 22, 2024 | 01:56 PM
  #31
ShoreRider's Avatar
ShoreRider
Originally Posted by harpwrench
It would be best to get advice on cam selection from whoever does the heads. 777’s not ideal with the compression you’ll have, 103 wet heads are only around 83cc’s. CR595 would be good
Harp: I'll be sure and include cam recommendations in my conversation with them both. Thanks for the input!
Old Feb 22, 2024 | 06:00 PM
  #32
Rains2much's Avatar
Rains2much
perfect recipe to screw up a valuable set of 110 heads
A mild conservative port clean up isn’t going to “screw up” anything. A clean up removing flashing isn’t going to ruin anything. A mild clean up around the guide will only increase flo. A good valve job will only promote good seal and promote flo. There is plenty of meat left for someone to take thousands of your dollars to get that hour upon hour of flo-bench testing to show you a piece of paper that says it will do that last 10-15% you’re so eager to pay someone else to do, because you can’t or are too scared to try.
None of your response shows you know anything about head porting except you believe in the money you spend someone else to make you feel like they did it right. Go break some heads, try porting.. bolt it on a bike and go see. A flo-bench won’t give you much of a meaningful answer. It’s like a dyno.. it will show you mathematical hypothesized measurements that statistically show improvement. I’ve spent money having some heads professionally ported. Three sets actually, I’ve done it myself. I’ve ruined heads and of gotten lucky. I stand behind what I said because I know they are facts. I’ve done it too many times to take the time to argue with someone who is clueless.. so I’m leaving this thread not offering any more real experience or help.
Old Feb 23, 2024 | 08:10 AM
  #33
bustert's Avatar
bustert
yep, a dyno is just a tool, a predictor not written in stone. seen tooooooo many times a shade tree smoke a dude with a pocket of certs from a dyno.
unless you are going track and have highly modified engine and intake tract, leaving the intake alone for the street is better as it adds to the mix, more important on a carb. the hd tract is tooooo short, spend your money on the exhaust side.
all said and done, probably be cheaper to buy a known good performance package with all the bells and whistles.
i agree with mr. rains. man have i messed up some stuff but the GOOD thing is i learned. my experiments with 5 porting a suzuki like a yamaha was a bust and building toooo big has it own hazards, my 305 honda would stay up with a 750-4 within 1>2 bike lengths until it topped out. the killer was i could only get 3 runs if lucky before the rings shattered and blue smoke appeared. happened so many time, i developed a way to pull the top end off in frame.
i build pedal steel guitars now and i still learn from my mistakes, makes a better machinist for sure.
Old Feb 23, 2024 | 11:05 AM
  #34
harpwrench's Avatar
harpwrench
If you would have asked why I disagree with you on 110 heads instead of assuming I’m a dummy, you might have learned something. Take your meds and go for a ride
Old Feb 23, 2024 | 11:09 AM
  #35
Rains2much's Avatar
Rains2much
I’ll glance in my rear view mirror, doubt I’ll ever see you catch up enough.
Old Feb 23, 2024 | 11:12 AM
  #36
ShoreRider's Avatar
ShoreRider
I thought you said in your previous reply you were leaving this thread...not that you needed to announce your departure.
Cya!!
Old Feb 23, 2024 | 11:17 AM
  #37
Rains2much's Avatar
Rains2much
Cya!!
Well then quit replying to my posts.
Old Feb 23, 2024 | 11:21 AM
  #38
PureHybrid's Avatar
PureHybrid
I'd opt to have WFO Larry do some light work on the 110 heads, they'll flow great. Don't get too caught up on compression, doesn't NEED to be 10.5:1 to get a good runner
Old Feb 23, 2024 | 02:41 PM
  #39
Lonewolf176's Avatar
Lonewolf176
No, but with it and the right cam you'll get bonus points.
Old Feb 25, 2024 | 07:41 AM
  #40
roussfam's Avatar
roussfam
What a **** show. There always that one guy, then it starts
OP, good luck with your project
