Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Had this problem once bike would turn over but not start.
Ended up being bad o-ring on fuel line would'nt seat.
when i pushed up on fuel line under tank it started right up.
Please elaborate, which o-ring and how was it blocking fuel flow? The last and only thing done since the rebuild is the replacement of the lower o-ring in the quick disconnect tank valve last September; the original o-ring was leaking. I don't recall starting the bike since I replaced the o-ring so my first thought was I screwed up the o-ring replacement. I disconnected that line and some fuel leaked out and I could get fuel spray when depressng the plunger in the female/tank section of the valve. However, when reconnecting the supply line, it was very difficult to snap in the male end. Tried twice with no success, just wouldn't go all the way in but applied max pressure on the third go and it snapped in. In all the videos I have seen, it appears that the male fitting does not require maximum pressur to snap in to the tank valve. I don't know if that means anything but I don't think it should take max pressure to snap in the male side of the fitting.
EDIT: Relaced the lower o-ring in the tank quick disconnect; not the problem.
A test light won't find the problem.. If there are issues with electrical to the injectors, the ECU will declare an error.. If they are plugged, it won't..
Ok yea you need access to the injector connectors to plug a noid light to them to test. That could involve some work so your likely on the right track.
One other thing you might try is to remove the gas cap, turn the ing switch to run, ear to filler hole. Try to listen for fuel spraying around in the tank while the pump runs to prime the system Have ck'd a couple and actually saw fuel being sprayed. Pin holes in lines inside the tank. Probably Not does bike have a Security system ??
WP
Have removed the gas cap and can hear the pump priming; maybe 5 seconds. The tank is at least 3/4 full and, as I understand it, the noise from a leaky line in the tank won't be heard until the tank is belos 1/2 tank.
2005 FXSTD has a security system although I have never used it for anything; not even setting an alarm.
Another reason I don't suspect the injectors is that the OEMs were replace by the tuner less than 1000 miles back.
Me 3..A test light won't find the problem.. If there are issues with electrical to the injectors, the ECU will declare an error.. If they are plugged, it won't..
So if the injectors aren't pulsing, the ECM would throw a code? Check out my previous post about the quick disconnection at the tank; very difficult to snap back in. Hard to see inside the female end so not sure how to diagnose. Memory is poor but I thought I could see the lower o-ring when I replaced it but I don't see it now. However if it had been disloged, wouldn't the fitting leak?
It’s been too long ago for me to recall specifics. But I had an oring problem that prevented getting the line connected properly and fuel would not pass through the fitting. It sounds to me like it could be your problem from how you describe what you did. Always look at the last thing you fixed, first.
FWIW the last time I had a leak there I used a green oring from an air conditioning service kit and it’s been working great for a couple years now.
If they aren't getting an electrical pulse, the ECU will throw a code. They can get a pulse and be plugged tho..
The DTCs are P0261, P0262, P0263, P0264.
The thing is when there aren't any codes, it has to be fuel pressure to the injectors or them being plugged. The ECU doe not have any way to detect fuel pressure. The EFI system lacks pressure sensing.
You can try simply holding up on the fuel connector while trying to start.
I sure hope you have a pressure tester on order. IMO it's more important than a compression tester on EFI bikes.. It should be used any time the fuel system has been worked on to check for internal leaks.. I done work and had leaks afterwards.
I looked inside the female side of the tank quick disconnect although I doubted anything wrong just becaus a lot of pressure was required to reconnect. I replaced the lower o-ring; not the issue.
You can try simply holding up on the fuel connector while trying to start. I sure hope you have a pressure tester on order. IMO it's more important than a compression tester on EFI bikes.. It should be used any time the fuel system has been worked on to check for internal leaks.. I done work and had leaks afterwards.
Convinced the tank fuel connector is not the issue. Fuel pressure tester is ordered; delivery by the end of the week.
Question: Even though the pump is priming; fuel pressure could still be the issue? So if pulling the guts from the tank, replace fuel pump; filter; top plate gasket;regulator and all the connecting lines/clamps? Assuming all OEM replacements unless someone has acceptable aftermarket replacements.
I will be looking for tips/tricks; do'/dont's for the fuel system R/R. I have done the R/R on my old FLHT to adjust the float level but did not replace any components.
Well that's outta the way.
A number of times I have been fiddling with that connection with no luck.
One of the guys walks up ,gives it a try __ it's in SMH lol
