Need Some Help
Old Feb 27, 2025 | 08:35 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Mine sits 6 months or so for last 4 years. 04FI TCb. Totally stock. 50k on it.
When I get to VA, I put the battery on the maintenance charger for a few hours and put it in bike. I syphon 4 gallons out and refill with new fuel.
It takes a good 15 minutes to get oil bag refilled driving at neighborhood speeds.
It also is extremely hard to get it to start if you don't make sure it's running and both cylinders are clear if you let off the start button too soon.
I have always thought it tends to flood its self. Opening the throttle a tad clears it.
Read this to understand that P55Pb. It's not an error code.
https://www.hdforums.com/forum/touri...de-p-55p6.html
It's possible, enough condensation in bottom of tank got into line from pump to electors. Hit it carefully with misted fuel spray in front of throttle body to run it enough so line clears.
Old Feb 27, 2025 | 08:45 AM
Fat11Lo's Avatar
Fat11Lo
Just because it's EFI doesn't mean that the basics still don't apply, need fuel , spark, and compression. Figure out which one you don't have, then dive down the electronic rabbit hole
Old Feb 27, 2025 | 09:49 AM
Max Headflow's Avatar
Max Headflow
What JP says makes sense.. What DLJ is reading is not an Error code.. Chances are that the engine light is temporary likely a crank sensor code.. Motor can throw a crank sensor fault if the motor stalls. If you hit the starter, the ECU see the crank signal and clears the code. You are back to fuel pressure / fuel. My guess anyway.
Old Feb 28, 2025 | 05:50 AM
buell95's Avatar
buell95
Had this problem once bike would turn over but not start.
Ended up being bad o-ring on fuel line would'nt seat.
when i pushed up on fuel line under tank it started right up.
Old Mar 1, 2025 | 03:40 PM
djl's Avatar
djl
Update #1
Got some other rat killin done and had time to get back to the no start bike. Cleared the code that was not a code. Got spark, good spark. Fuel drips from the tank quick disconnect when disconneted and sprays when depressing the valve. I have not confirmed fuel is getting to the throttle body; can't get to the disconnect for the supply line from the tank, too much crap in the way. I did spin the motor over a few times and in the process found front plug with crack in the exposed ceramic, spark was arcing outside the boot, replaced it. Neither of the plugs was wet after several spins; not sure if that means anything but I expected them to be wet with fuel. Not sure where to go from here.
Old Mar 1, 2025 | 03:51 PM
Spanners39's Avatar
Spanners39
Check your crank sensor ohms, should be .9-1.1 ohms sorta thing...0 is bad.
I know it is showing as a fuel fault but....
Old Mar 1, 2025 | 04:30 PM
Max Headflow
That's K ohms.. 900-1100 ohms.
DLJ,
Squirt fuel in the intake. See if the motor tries to start.
Old Mar 1, 2025 | 04:54 PM
WP50's Avatar
WP50
Hold open the throttle blade and give a 1-2 seconds spray of brake clean.
Let throttle blade close and hit the start button.
See if it tries to fire up.
WP
Old Mar 1, 2025 | 08:27 PM
djl's Avatar
djl
That's K ohms.. 900-1100 ohms. DLJ, squirt fuel in the intake. See if the motor tries to start.
I do appreciate the suggestions but ohms, amps, etc. is a foreign language. I have a multi meter and can do very basic testing with it but you are going to have to go deeper; I need a "how to" in very basic terms. I have no idea what K ohm areI have searched the internet looking for a diagram or picture but can't find anything. I will try starter fluid in the intake as well.
I have been told that the code was not a code (P55Pb); doesn't look like a Harley code but WTFDIK. When Googled fuel fault was one of several issues that showed related which is why I was thinking a fuel delivery issue and it still might be. The code has been cleared but no change. When I was cycling the ignition today, one cylinder fired for one revolution twice so I am thinking the solution has to be something simple.
Thanks to those that have responded.
Old Mar 1, 2025 | 09:17 PM
Max Headflow
Sorry, engineering talk K ohms or better Kohms is short for kiloohms. It simply means 1000s of ohms.. 0.9K is 900.
