Need Some Help
Add: You probably want to replace the pump.. The fuel flows through the electric motor past the armature / brushes..
I am replacing everything, pump, filter, regulator, quick disconnect tank valve and top plate gasket. After seeing the deteriorated sock, I am not so sure I want to replace that part. Would you?
Do you put additives in the tank? Stale ethanol gas will do it..
How could the exit hose disconnect? IIRC, there is no clamp at that connection so I thought I might have disonnected it by pulling on the pump assembly to cut that hose at the filter but I also thought that connection should be tight enough that I could not pull the hose off.
The only additive I add to the fuel is Star Tron or Stabil; every so often I run some MMO through. I don't know how long it takes for ethanol fuel to go stale with a stabilizing additive. The gas in the tank was from a fillup in September last year with the appropriate amount of Star Tron added.
If the filter plugs and the pump goes to max pressure; could that cause the pump to fail? If pump is at max pressure could that push the exit hose off the connector? I still don't know what caused the failure.
There isn't any clamp but the hose is pretty stiff. Its possible that the stabilizer did something to the hose maybe not. Either way I've not been able to pull on off the bottom valve. It's stuck on pretty good.. In fact bet you have issues pushing the hose on to the fittings. I use a heat gun and get hose real hot.
The pump design will limit the pressure.. The pump is like the water pump in an old outboard. It has a ton of fingers.. I'd bet once the pressure gets to a certain point it stops building. Cut the old one apart.
The fact that you go 0 fuel pressure says that something popped loose. Even a plugged pump or filter would generate some pressure. The fact that you had none and gas dribbles out of the connector says a hose popped off or filter / regulator assembly popped apart.
Well, aside from the deteriorated sock I know why the fuel pressure was zero; the exit line separted before the connection at the quick disonnect valve.
I started to drain the tank as Max suggested but the handle bars prevented the tank from being raised back to front so I pulled the tank back and raised front to back and was able to siphon all but a few ounces; put the tank back in place and removed the quick disconnect. I still can't figure out how/why the exit line broke where it did; I think this is unusual.
Everything back together, replaced every thing. The regulator that came in the Fuel Pump Factory kit was a bitch to push in. Waiting for the new exit line/quick disconnect assembly to put all back together.
Question: Removing the system from the tank requires straightening out "leg" with the filter. If installing with that leg straightened out, how do you retract the leg back into the correct position. Maybe it will be obvious when I install but if there is a trick; those of you who have done this, let me know.
I also found an unknown rubber item rolling around in the fuel tank.
Pictures attached.
Have see a rubber grommet thing on the bottom of the pump then the sock
Serves give the pump something to set on as well a noise damper.
Hope the rest goes easy WP
