Cylinder scoring
Old May 21, 2025 | 01:14 PM
Emascarri's Avatar
Emascarri
Stage IV
Default Cylinder scoring
Hi,
I've recently purchased a 1992 softail custom with about 23k on it. Previous owner told me he had the cylinders honed and painted black about 700 mi before selling it (but the bike had been sitting in the garage for about 2 years when I bought it).
I've been tearing the bike down because I want to sand and polish the fins to get the engine as close as possible to when it was new. Yesterday I removed heads and cylinders, but what I see is not what I expected to see on a couple of "freshly" honed cylinders: a lot of carbon build up as well as discolouring and scoring on bores and some on pistons too (see pics).
What do you guys think it might have happened here?
Any suggestions greatly appreciated
Thanks!
File Type: pdf
File Type: pdf
File Type: pdf
Old May 21, 2025 | 01:43 PM
MURPHCC1's Avatar
MURPHCC1
He lied to ya!
Old May 21, 2025 | 01:45 PM
Emascarri's Avatar
Emascarri
Stage IV
I'd definitely agree, if I hadn't seen the receipt of the workshop!
Anyways, is it severe? Do I need to rehone the cylinders?
Old May 21, 2025 | 02:03 PM
MURPHCC1's Avatar
MURPHCC1
Might as well while they're out, check for other bore wear, clean up those pistons too, change the rings and gapped CORRECTLY!
Old May 21, 2025 | 03:01 PM
djl's Avatar
djl
Freshly honed cylinders could present with scoring for a variety of reasons; poor fitment; too rich/too lean fuel; too much timing, etc. At a minimum and before doing anything, the cylinder bores should be checked in torque plates to insure the bore is straight and the pistons measured to check piston to cylinder wall clearance. If the cylinders were bored, new pistons would have been installed and the carbon build up on the pistons is more than would occur on new pistons after 700 miles of operation which begs the question if the cylinders were bored. The piston skirts are not scuffed and can be reused if fitment checks out and carbon removed.
Old May 21, 2025 | 03:27 PM
Emascarri's Avatar
Emascarri
Stage IV
Thank you, I'm thinking to have the cylinders inspected at some reliable machine shop
Old May 22, 2025 | 06:58 AM
bustert's Avatar
bustert
snookered
there are shops and there are shops
today it is very easy to print material even with correct logos and such. when i do a guitar repair and the headstock logo messed up or gone in the process, the mfg will NOT sell you one, most are silk screened. that leaves me having to get a jpeg of it off the net and scale it to fit the headstock and have a reverse image made and use that as a silk screen to put the guitar back correct.
i once saw a youtube video of a dude who says he is the premier shop and everything he does is white on rice but when i saw him remove an xl pinion gear with a claw hammer, that tells a diff story, would not let him put the chain back on a schwin bicycle.
Old May 22, 2025 | 11:44 AM
Max Headflow's Avatar
Max Headflow
Looks more like the guy installed fresh rings without honing the cylinder..
Old May 22, 2025 | 10:40 PM
98hotrodfatboy's Avatar
98hotrodfatboy
I would have a reputable shop measure the pistons and cylinders and go from there...
Morrid7
Twin Cam Motors
15
Jan 26, 2022 10:37 AM
60Gunner
Engine Mechanical Topics
14
Jul 21, 2020 11:38 AM
TruckerXbones
Jul 15, 2020 05:45 PM
freud
Shovelhead
Dec 11, 2013 02:26 PM
jdusty21
Ironhead
Jun 29, 2007 12:31 PM
