Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Can't go wrong with these Kibble white, but if you have the same identical Leak with brand new, I would say there's something going on with the head or the theads..
No, I have 4 Husqvarna releases, all leak inside, not in the threads. I know because I plugged two of them with glue, and then they stopped leaking (e. g. no bubbles in the soap water) and I got only 5 and 5.5 % leakage. Kibblewhite look exactly the same as Husqvarna, they are just 10-20 times more expensive. (But thanks, anyway.)
I want to add the tests were made at 30 psi and perhaps they need much more to seal. I can test with soap water later when I have assembled and can make the starter running.
It was a bit noisy from the valve train at first, but it became much better when the oil started to circulate. Still running on the canned tune (far too rich). But overall I feel very happy with this cam.
I want to thank everybody in this thread and I wish you all a great riding season. (For you in the southern hemisphere I wish you a great mechanic season).
Best Regards
Oak Mountain Rider
