VOES Switch Explained
Old Apr 4, 2022 | 10:07 AM
  #31
Txwezl's Avatar
Txwezl
3rd Gear
Originally Posted by 46u
What a VEOS switch does is advance the timing when there is enough vacum is pulled as the rpm go up. Yes if the VEOS switch is bad can keep it from reveing up and can mess up your motor from running retarded all the time. A quick test to see if it is work at all is disconnected both wires to the VEOS and sucking on the tube and with a ohm meter see if it gets continuity while sucking on it. Now to see if you is kicking in at the right suction you have to have a vacuum pump with a gauge. If the suction is off you and adjust it if you dig all the goop out of the end as there is an adjustment screw under it. Most time the problem is the diaphragm has gone bad in it.
That is not correct. The VOES retards timing to eliminate detonation.
Old Apr 4, 2022 | 11:05 AM
  #32
Max Headflow's Avatar
Max Headflow
Well with the WOES disconnected, doesn't it run the slow curve? Doesn't that mean the ignition advances with the VOES connected and low manifold pressure?
I'll agree that running the slow curve isn't going to keep the motor from reving.. It might make partial throttle response feel a little sluggish and kill the mileage. If broke and the switch is closed all the time, you could get detonation.
Old Apr 4, 2022 | 11:39 AM
  #33
t150vej's Avatar
t150vej
Correct.
Opposite of that.
The voes is simply an on/off switch connected to ground. That ground signal is sent to the ignition module when the switch is closed (vacuum above pre-set value). The ignition module changes the timing, based on engine rpm and that ground signal.
With vacuum and closed switch, the timing is advanced to a value based on rpms as read by the module. With switch open (low vacuum), timing retards to a value programmed into the module and also based on rpm.
The voes is "closed" most of the time with the engine running. A blip of the throttle will drop it out maybe 1/2 to 1 second. On a long pull, uphill or WOT at lower speeds, it'll be open longer.
Depending on the module (stock or aftermarket) above a certain rpm, the timing is fully advanced by the module, regardless or voes signal or rpms.
Old Apr 4, 2022 | 12:12 PM
  #34
Max Headflow
Originally Posted by t150vej
Correct.
Opposite of that.
Not the opposite. The same. Isn't low manifold pressure the same as vacuum? I just said it different..
Old Apr 4, 2022 | 12:26 PM
  #35
t150vej's Avatar
t150vej
Quit trying to make me use my brain Max. One brain cell knows my name, one got lost years ago and the third one is out looking for it.
Old Apr 8, 2022 | 04:13 AM
  #36
Yankee Dog's Avatar
Yankee Dog
Yes, Max and t150 are both correct.
It's just a play on words with how vacuum is described, but agree when vacuum reaches a certain point it activates the advance curve. There! Added another word to the mix to help confuse thing more.
Good movie, 'shakin the bush boss", shakin the bush".
Old Apr 8, 2022 | 07:31 AM
  #37
98hotrodfatboy's Avatar
98hotrodfatboy
On heavier bikes 4.5"hg and above will allow the switch to make to ground advancing the curve and I believe it's 6" hg and above for Sportster's..
Old Apr 8, 2022 | 10:57 AM
  #38
Yankee Dog's Avatar
Yankee Dog
Old Apr 8, 2022 | 02:29 PM
  #39
98hotrodfatboy
That's too much reading for her....
Old Sep 23, 2022 | 08:59 PM
  #40
R_polly's Avatar
R_polly
Default 1984 FLHTC EVO VOES Question
Does anyone know what VOES for 1984 electra glide evo 3", 4", 5", 6" or what? Can't seem to find information on it anywhere. Thanks in advance.
