VOES Switch Explained
Old Sep 29, 2022 | 06:39 AM
  #51
Yankee Dog's Avatar
Yankee Dog
Yeah, I'm kind of lost on what or where R.polly is at with the bike. Once the new VOES is in, start a new thread with all the particulars. You issue will get resolved.
Old Sep 29, 2022 | 07:31 AM
  #52
R_polly's Avatar
R_polly
I have another thread thread that all is going on and what has been done. That is what led me to this one. Sorry if this was not the right place to ask questions about the VOES as I couldn't find anywhere else that had any good information. No other post will be made in this thread.
https://www.hdforums.com/forum/engin...huts-down.html
Old Feb 4, 2023 | 10:24 AM
  #53
rellquist's Avatar
rellquist
When the VOES closes, how much RPM change is there? A few hundred RPM?
Old Feb 4, 2023 | 10:42 AM
  #54
t150vej's Avatar
t150vej
Assuming no intake leaks or carb adjustment issues - from an idle speed of approx 1000, the rpm will drop approx 300-400 when the switch opens.
Setting the idle speed with the switch open then closing the voes, the rpm rise won't always be consistent.
Old Feb 5, 2023 | 09:20 AM
  #55
cycleman11's Avatar
cycleman11
On these older bikes like mine, I'm pretty sure that a lot of the problems with the VOES are related to the vacuum petcock. I know on my bike I was having some cold starting issues and not always easy to get a good idle. It was pretty good when fully warmed up but seemed a bit lacklustre in acceleration. Not bad, just not what I thought it should be.
I never thought it was VOES related but did suspect the vacuum petcock because I had the odd drop of gas from the petcock area and the cold start issue even with the choke activated. It seemed to act like a lack of fuel as the bike is not jetted rich.I replaced the vacuum petcock with a manual one and blocked off the vacuum port for the petcock at the VOES switch. Engine starts much better when cold and idles better. I also have no more fuel drips.
With our winters up here it will be awhile before I can test the bike out, but from my initial observations the change in petcocks has made it a different bike. When I now think about it and how the vacuum advance worked on the older cars, the symptoms are very similar. If I still have some issues in the spring, I'll look at replacing the VOES. I replaced the stock ignition module with the Dyna 2000, last year and it wants the VOES ( at least on the setting that I run ) so it was wired into the VOES, so it seems the bad vacuum petcock was likely causing my issues. Time will tell.
Old Feb 7, 2023 | 10:36 AM
  #56
rellquist's Avatar
rellquist
Thanks. With the bike idling, there is no change to speak of. At a constant speed with about 3000 RPM, my tach will just jump up 2-300 RPMs and then go back. It happens continuously. I can't really feel the bike surge. I have changed the tach, coil, plug wires and VOES as part of a general tune up. The previous tach would swing wildly around all the time so I don't know if this was happening then or not but with a 34 year old bike I thought it best to change those items. Previously someone had mentioned that placing a resistor in line with the Tach feed would reduce the wild swings which I did but it didn't help the Tach so I changed the tach. I wonder if it could be what's causing the RPM jump. Maybe its building up some voltage in the line which is then discharging somehow. Weird!
Old Feb 7, 2023 | 10:46 AM
  #57
Max Headflow's Avatar
Max Headflow
There is nothing wrong with the bike. I've seen various brands of aftermarket tach bobble up down 300 rpms. Some were real bad. If you want to fix it, go with Autometer. Kosos might work also.
Old Feb 7, 2023 | 11:32 AM
  #58
98hotrodfatboy's Avatar
98hotrodfatboy
Deleted.....
sgl0226
Feb 22, 2021 06:24 AM
Jephilosoraptor
EVO
Aug 4, 2015 04:10 PM
2JADED
May 29, 2013 10:45 PM
two tall
Apr 1, 2011 01:22 AM
police
14
Jul 12, 2010 06:10 AM
