Mostly stock 88TC cam choices
Old May 9, 2014 | 02:05 PM
nhrider1's Avatar
nhrider1
Originally Posted by Quickrunner1
The Andrews site says the 48 needs high lift springs, I am going with quickie adjustables so I dont need to pull heads or rockers. Anyone run these cams with stock springs on a combo like mine?
I'm running 48's in a 2005 TC88 with stock heads. No problems, the beehive springs will accommodate the lift.
Old May 9, 2014 | 09:04 PM
Quickrunner1's Avatar
Quickrunner1
Did you go to the 48's from stock? How do you like them?
Old May 10, 2014 | 06:42 AM
nhrider1's Avatar
nhrider1
Yes I went from stock to 48's. Good cam for an 88. Lost of torque down low and improvements across the entire range. Smooth power delivery.
Old May 10, 2014 | 07:03 AM
prodrag1320's Avatar
prodrag1320
Thumbs up
A+ on the 48`s here
Old May 10, 2014 | 08:41 AM
magnum629c's Avatar
magnum629c
Hows this 48 compare to a 21 down low where most people ride
Old May 10, 2014 | 02:59 PM
prodrag1320
the 48`s will provide power down low,any lower you really wouldn't want to be "stabbing" it anyway (about 1800-4500+,higher with mild headwork)
Old May 10, 2014 | 03:15 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
The 48 does close 1 degree sooner.
Scott
Old May 10, 2014 | 08:51 PM
bagster04's Avatar
bagster04
Ss551 is a perfect 2 up can for that bike plus the ez start helps.
Old May 11, 2014 | 05:05 AM
custom_fatboy's Avatar
custom_fatboy
yea i run the 204's, dont get them, they are ok but they start climbing at 1500rpm till 2400rpm then they have a small dip untill 3000rpm then they climb again and at 3500rpm you'll be at the same amount u been at 2400rpm climbing till 4500rpm then it goes down again it doesnt go down much but there is a 15 foot pound torque difference between the dip and the max torque output.
according to some here the 48's are good so i might try those when i want to get rid of these
Old May 11, 2014 | 07:37 AM
DresserDude's Avatar
DresserDude
Subscribed, I have the same setup so far, would like to do a cam change as well.
