Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
[QUOTE=Quickrunner1;12699143]The bike is a 05 88TC RoadGlide, only mods are SE stage 1 aircleaner, Rienhart true duals, and a Power Commander 3. Reading my *** off on the subject and this is a list of some recomendations I have read. Also I am Not pulling heads or going gear drive or raising compresion, just going Cyco tensioner shoes, S&S quickie adjustable pushrod kit, new bearings and cams. From the list below what is best, 2up riding 1/3 of the time, dont need a 5500 rpm hot rod but want good power improvement and a cool idle.
