Do We Have A Cam Chain Problem
Old Jul 17, 2014 | 01:52 PM
rutcutter999's Avatar
rutcutter999
Default Do We Have A Cam Chain Problem
I have a couple of friends who have 2012 models with the 103. These guys ride quite a bit so both have around 20K miles. One of their bikes, a Street Glide, broke it's cam chain a couple of weeks ago. I was with him and we were riding along on the highway about 60 and it made a noise and just broke. The second guy who has a Road Glide got worried and took his in. The chain was worn out.
Now the dealer that both bought their bikes from is saying that everyone is going to have to change the chain every 20K miles or so. I hope like the devil that this is not right because unless you can do it yourself it is not a cheap repair.
My question for you guys is:
1. Have any of you heard anything about this?
2. Have any of you had this problem?
Thanks.
Old Jul 17, 2014 | 09:01 PM
magnum629c's Avatar
magnum629c
Only issues I heard were the 99- 2006 bikes.. Maybe a few newer bikes but only if they had a **** ton of miles the newer bikes are much better
Old Jul 17, 2014 | 09:03 PM
magnum629c's Avatar
magnum629c
That gear drive is not answer either as most newer bikes all have some kind of runout... Its really not a big job I just plan on going in there every 30,000 miles and change get them what else can u do... I also do have the hydro cam chain upgrade done
Old Jul 18, 2014 | 10:42 AM
rutcutter999
Default Magnum
Tell me more about the hydro cam chain upgrade. I am not familiar with it.
Thanks.
Old Jul 18, 2014 | 10:45 AM
rutcutter999
Default Magnum
Tell me more about the hydro cam chain upgrade. I have not heard of it before.
Thanks
Old Jul 18, 2014 | 11:02 AM
djl's Avatar
djl
Originally Posted by rutcutter999
Tell me more about the hydro cam chain upgrade. I have not heard of it before. Thanks
All '07 and later models have the "hydro chain" upgrade; all have roller chains and hydraulic tensioners. The only upgrade for the later models is the replacement of the cam plate with a billet plate and a higher capacity oil pump. Of course, there is the gear drive option which is definitely an upgrade.
The two incidents of broken cam chains are the first I have ever heard of. JMHO, but I doubt that broken cam chains are an epidemic nor will they need replacement every 20K miles. Also JMHO but I doubt that the cam chains just "broke" and I suspect that something else caused the cam chain to break. If you can, provide a follow up with the results of what the techs find when they tear down the motors.
Old Jul 18, 2014 | 03:18 PM
rutcutter999
I will do that. The thing that bothered me the most was not the fact that two bikes had failures but that the dealer seemed to think that there might be a large scale problem. If any of you guys hear of any of these problems please keep us updated.
Old Jul 20, 2014 | 08:18 PM
djl's Avatar
djl
Don't take your bike to that dealer for service. Get a service manual and DIY.
Old Jul 26, 2014 | 04:43 PM
ONEEYE05FLSTC's Avatar
ONEEYE05FLSTC
Default cam chain
The dealers have mechanics, not technicians. I changed my 05 88B from the stock timing type chain and phenolic tensioners at 50k to the andrews roller chain and hyd poly tensioners. I just did, (at 101k) a bottom end tear down and repair, (fixing dealer caused crank bearing issue) and my chain was like new and the outboard tension shoe had minor wear. I'm a retired millwright and I have seen lots of roller chain failures on machinery. Make sure it's getting oil and check it once in a while; they aren't that hard to take of, unless it's the inner chain.
Old Jul 26, 2014 | 05:23 PM
dan conner's Avatar
dan conner
a 2012 should run 100k without a cam chain problem...no telling how many compensators and other problems you may encounter. i am pushing 50k on my '12 EGC and do not worry about cam chains--too much other stuff to worry about!
rkoivisto
Jun 13, 2011 07:54 PM
jsgilbert2
Aug 27, 2009 11:31 AM
SC-Longhair
Feb 24, 2009 05:41 AM
Professor
May 27, 2007 01:22 PM
airjoe
Dec 4, 2006 06:08 PM
