replace or rebuild oil pump
Old Jun 29, 2012 | 11:08 PM
gnafin's Avatar
gnafin
Default replace or rebuild oil pump
have a 1984 early EVO, i have to replace the oil pump.... and tricks or info on how to do it? i am going to look in the book but thought i woould ask here as well...
Old Jun 30, 2012 | 03:08 AM
Spanners39's Avatar
Spanners39
Rebuild it according to the manual and no one gets hurt. Prime it before starting the bike and also crank the motor over with no plugs until the oil light goes out before starting it.
Getting the seals to go in straight and level can be an art in itself.
Old Jun 30, 2012 | 09:11 AM
miacycles's Avatar
miacycles
If the body isn't to badly scored then rebuild is the way to go. However if there is a lot of scoring then a new one is needed. Plus you need to figure out where the junk is coming from that is doing it or you will be re-doing it again along with whatever part that is failing. Hope this helps.
John
Old Jul 1, 2012 | 11:42 AM
gnafin's Avatar
gnafin
well, i guess i will try the rebuild... now how makes a good rebuild kit? here is what is happing... the oil is coming out of the breather in a fast flow... so i dont think the oil is going back to the tank. check ball is ok.
Old Jul 1, 2012 | 04:24 PM
Jim Kraft's Avatar
Jim Kraft
Check for a sheared key on the scavenger side of the pump.
Old Jul 1, 2012 | 07:01 PM
machinehed's Avatar
machinehed
Default oil
If oil pres. was ok before this problem , your oil pump is probaby ok., oil pump hard failures are very very seldom .
Check all other possibilities before assuming the oil pump is the culprit.
I would suggest you ask your local HD Dealer mech. or service guy for advise before you start tearing into it .
Check for blocked oil lines ,oil tank sludge, deteriorated timed crank breather
gear screen , blocked up tappet oil screen , impacted/blocked oil filter etc.
Old Jul 2, 2012 | 08:57 PM
gnafin's Avatar
gnafin
i just put in a differnt oil filter(harley) the leak got better but still flows out of breather.... i will try to reseat the ball. one thing the oil that is comming out of the breather smells like gas... but could just be me...
Old Jul 3, 2012 | 03:44 PM
miacycles's Avatar
miacycles
If it smells like gas, what it probably is, is reversion. Could be your valves need to be adjusted if you have adjustables, or the intakes may be leaking and the top end needs to be freshened up. Hope this helps.
John
Old Jul 7, 2012 | 02:26 PM
gnafin's Avatar
gnafin
well, i got the pump off(105 out) and yep, the key was broke... so clean up and reinstall it all...
Old Jul 7, 2012 | 09:48 PM
RidemyEVO's Avatar
RidemyEVO
Was just curious but is it normal for a stock oil pump to seep oil?
