winter storage
Old Nov 14, 2014 | 09:45 AM
flhchaz's Avatar
flhchaz
I also start mine and let them come up to temp and have never had any issues. the reason that I don't change the oil before winter, is that my bikes live in a shed all winter and there is not heat. I worry about the viscosity of the oil breaking down because of the extreme temps.
Old Nov 14, 2014 | 12:05 PM
Beemervet's Avatar
Beemervet
Cold temps do not break down the viscosity of oil.
Old Nov 14, 2014 | 05:35 PM
Hackd's Avatar
Hackd
Originally Posted by traildog
Hey Hackster, why not just leave the battery in the bike?
I have more batteries to charge than tenders. Easier to just consolidate the group.
Old Nov 15, 2014 | 09:37 AM
0maha's Avatar
0maha
I never winterize. Here in Omaha we usually manage a few days here and there all winter where the streets are dry and the temps are warm enough for a short ride.
Old Nov 15, 2014 | 10:34 AM
nealc's Avatar
nealc
2nd Gear
I think your winterizing steps depend on your situation. I live in a cold climate and it can be many months between fall and spring riding. However, the air is very dry here and the bike stays in a heated garage. I have never done anything special for storage other than top off the battery once in a while, and I have not noticed any problems from storage. If there was a lot of humidity and condensation I would worry more about the oils, tanks, and ethanol.
Old Nov 15, 2014 | 09:20 PM
Roadghost's Avatar
Roadghost
I disconnect the battery and put it on a battery maintainer to avoid component drainage. I don't run my stored vehicles in the winter because it just blows water into the exhaust pipes and if they don't get hot enough they can rust. I only change the oil if I have more than 1000 miles on it, otherwise it is still fresh enough to stay there. I also cover the chrome with a thin layer of oil to protect from condensation, and put a moving blanket over it, then a bike cover. This has always worked for me in a cold garage.
Old Nov 16, 2014 | 07:33 AM
MJHJEA's Avatar
MJHJEA
What is a "moving" blanket? Does the pillow go under the front or rear tire? Just kidding….I'm sure there's some rationale behind it. I've always just used a nice HD cover with no issues.
Old Nov 16, 2014 | 07:42 AM
MJHJEA's Avatar
MJHJEA
Brain fart…..think I know what you mean by moving blanket. I always park on thick carpeting as well to help with the condensation.
Old Nov 16, 2014 | 08:56 AM
Dr.Hess's Avatar
Dr.Hess
Moving blanket:
http://www.harborfreight.com/72-inch...ket-66537.html
Old Nov 16, 2014 | 03:00 PM
wild_one's Avatar
wild_one
I live in central Indiana. I add fuel stabilizer, fill the bike with fuel and let it run through the system and the battery is on the tender all winter. In the spring I drain the bowl on the carb and change all fluids, have never had an issue in 5 years.
IRON1250
EVO
Oct 22, 2016 09:06 AM
McMurphy
EVO
44
Nov 12, 2013 01:17 PM
sgnden
Dec 27, 2010 12:29 PM
champ198
Dec 18, 2010 05:45 AM
Tommo
Dec 2, 2007 04:48 PM
