Confused. Engine build or buy.
As the title says Im confused whether to buy an S&S111 motor or build a mild motor.
This bike pictured is ridden 2 up 95% of the time and you could add about another 400 lbs between my wife and I. It has Progressive heavy duty suspension front and rear. And spends a little time on the interstate but mainly in the mountains.
The S&S111 is approximately $5500.
And I could probably build a nice Evo for about half the price.
Build would be standard
Rebuild heads (port and polish, 3 angle valve grind, etc)
Still up in the air about cam
new lifters
new pushrods
Changing to a 2 to 1 exhaust
etc, etc
my questions are,
Im not sure I want to qo 10.5:1 as I cant guarantee that i would be filling up at the same station.
But stock compression leaves alot to be desired. Will I gain enough by making sure the cylinders are straight with the cases and adjusting with gaskets? or do I go to 9.5:1 pistons.
Am I missing anything.
If it helps, I dont know alot about these motors but I do like to turn wrenches. Not looking for a high performance motor just reliable.
sorry for the long post.
In my '98 Ultra, I ran a set of flowed heads, Weisco 10:1 pistons, EV 3030 cam from Comp,a Power Commander for the MM injection and a 2 into 1 Pro Pipe. Got about 78 hp (stock was like 53 or so,) and ran it 64,000 miles before I sold it. It was a great dependable motor and I didn't have $2000 in that upgrade.
An SS engine would be awesome, but one of the high comp variants + available fuels on lonely roads might lead to issues.
My better half informed me she would like to have a new Ultra so we can go on longer rides. Who the hell am i to argue with that logic.
So on to build something. Not sure yet but ill start with the motor.
Thank you for the input...
