Why the rear rocker boxes?
Old Jan 3, 2015 | 09:42 AM
Harleycruiser's Avatar
Harleycruiser
Originally Posted by 2manyhobbies75
Now that's funny...
My favorite saying is "While you are in there"
Old Jan 3, 2015 | 10:09 AM
ican's Avatar
ican
Snap-on makes a special ratchet wrench for this job. Unlike most Snap-On tools, it is not real expensive. It is sold under the Blue Point brand.
Old Jan 3, 2015 | 10:22 AM
Rhino-1's Avatar
Rhino-1
Specs? Part number? Pic? Thx!!
Old Jan 3, 2015 | 10:27 AM
ican's Avatar
ican
Blue Point HD6529 rocker box wrench
Old Jan 16, 2015 | 07:04 PM
Crashone's Avatar
Crashone
Got all the parts this week. got my tools ready, now to find the time. Hopefully in a few days.
When I pull these apart is it fairly easy to tell which gasket was leaking? I am hoping not to have to change the very bottom rocker gasket. If I do I'll have a few more questions for sure even though I have a manual. With the new James Gaskets kit there are new copper crush washers and the fiber washers as well as pushrod tube O-rings. I am going back and forth, should I just tear it down and do them all or leave what is not leaking be.
Old Jan 16, 2015 | 07:31 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Might as well replace them all.
Use either the copper or the fiber washers but not both.
Old Jan 18, 2015 | 07:44 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Default Do yourself a Flavor...
I would definitely replace all the gaskets including the pushrod tube o-rings. you will be thanking yourself later.
Old Apr 7, 2015 | 07:51 PM
Crashone's Avatar
Crashone
Well now, the stars and planets finally aligned! Had a friend over to help and we knocked it out Monday. Changed all of the rocker gaskets and o-rings that came in the kit, took some time as some of those bolts were genuine FU bolts. Also change the o-ring on the crank position sensor and the case oil screen since I was there. I took it out for a 5-6 mile ride before I tightened the new engine mount all the way then took it for a 25 mile ride or so. No leaks and feeling smoother from the new front mount and handle bar mounts.
Old Apr 7, 2015 | 08:08 PM
texashillcountry
Dirt don't hurt
Glad you got it worked out.
Thanks for telling us the outcome.
Steevo12683
Engine Mechanical Topics
Aug 4, 2017 07:23 PM
Eunoterpsia
Nov 2, 2015 06:38 PM
tunlrat
Jun 24, 2015 11:37 AM
fergerburger
Ironhead
May 28, 2008 04:31 PM
Varooom
Feb 5, 2007 12:55 PM
