Ironhead A place to talk about Ironheads.
rear rocker box removal
Old May 23, 2008 | 04:09 PM
fergerburger's Avatar
fergerburger
Default rear rocker box removal
Is it possible to get the rear rocker box off without removing the head on a 71 XLCH. My manual does not indicate this....it looks like one of the bolts is obstructed by the frame. I'm guessing the head has to come (slide) off? yes???? thanks....ferg
Old May 23, 2008 | 04:13 PM
piniongear's Avatar
piniongear
Default RE: rear rocker box removal
The rear head has to come off with the rocker box attached. It has to go back on the same way of course........pg
Old May 23, 2008 | 07:39 PM
mojo2go's Avatar
mojo2go
You're not going to believe this, but I actually got my rear rocker box off my '81 XLS to replace a leaking gasket without taking the rear head off with it. It was a bugger to get off with all but a couple of bolts out of it but I wormed it out and off. No gouges in the box either.
Old May 24, 2008 | 03:54 AM
mk2007's Avatar
mk2007
I noticed that yourecomended Permatex no.3 on the gearcase cover in another thread.
Would you alsorecommend it used on the rocker box cover gasket?
Old May 24, 2008 | 10:02 AM
piniongear's Avatar
piniongear
Yes indeed! I use #3 for all the gasket surfaces and the reason is because this is a non hardening sealer. Two years later when you have to do it again you are able to clean the aluminum surfaces fairly easy, and without gouging the aluminum.
Compared to (if you had used hardening type) cleaning off some other stuff, #3 is very easy.
pg
Old May 24, 2008 | 10:05 AM
piniongear's Avatar
piniongear
Maybe the top tube on an '81 frame is a bit different than the older frames? Oh heck, I know it is different!
Did the rocker box go back on easily, or was this as much of a struggle as taking it off?
pg
Old May 27, 2008 | 05:33 PM
mojo2go's Avatar
mojo2go
It actually came off easier than reinstalling it. Trying to hold the bolts that had to go under the frame made it a pain.
Old May 28, 2008 | 04:31 PM
Moon Wolf's Avatar
Moon Wolf
Can't speak for the later bikes, but you sure couldn't take the rear rocker off on any of mine without remvoing the head!
Philip Wagers
Jul 11, 2018 02:21 PM
tunlrat
Jun 24, 2015 11:37 AM
Crashone
EVO
28
Apr 7, 2015 08:08 PM
woody0404
EVO
14
Dec 24, 2011 12:13 PM
Badger
Ironhead
Feb 15, 2008 10:57 PM
