Paint question
Old Jan 31, 2015 | 08:29 PM
  #51
WP50's Avatar
WP50
[QUOTE=CDF346;13655015]
Originally Posted by WP50
Not laquer if that's your question
Harley stopped using laquer in the mid 80"s
Mid 90's, I dunno. Probably acrylic enamel. But if your wondering if its safe to shoot on top of, yes, will be fine. Finish with 400-600 wet. If you want to be sure of seeing no sand scratches in the finish, take it to 600.
As long as it is Not Lacquer I should be OK
Take it to 600 ???
Even if I'm going to use a primer sealer before paint????
Got some scratches I'd like to be gone.
WP
Old Jan 31, 2015 | 09:13 PM
  #52
Tony_N's Avatar
Tony_N
Water based paints were just being pushed when I got out of working in a body shop in 83 or so.
Thanks WP
GM also tried the water based seam sealers in the 70s. Seams rusted like crazy.
A question crossed my mind. If someone might know or remember.
What kind of paint would be on this 1997 FLHT standard. Gotta get on another computer to get a pic up here
Well it started as a standard
Thanks WP
Sharp Electra Glide WP!
Old Jan 31, 2015 | 09:38 PM
  #53
CDF346's Avatar
CDF346
[QUOTE=WP50;13656337]
Take it to 600 ???
WP
600 is overkill, but its not much extra after 400, but its up to you.
You can fog it with a contrasting flat spray between each grit to "see" you are getting the previous grit scratches out.
If you not going to strip it, break and feather all your scratches and scrapes. Bomb it with 3-4 coats of surfacer. Fog it with a contrasting color and block it in diagonal motion. Knock it down with 120-150. You will see low spot you need to prime again. The rear fenders are usually pretty ripply in comparison to the front, tanks are usually pretty straight.
The thing about priming and painting; everybody has their own technique to get to the finish. None of them are wrong as long as it looks good when done.
Old Jan 31, 2015 | 10:00 PM
  #54
1CdnHD's Avatar
1CdnHD
Whatever paint line you end up choosing, get the TDS ( technical data sheet ) for all the products you are using. The TDS will tell you how to prep your parts ( what grit to finish prior to paint ) as well as flash times, mixing ratios, reducer options, gun set-up, re-coat windows etc....
The TDS sheets are either available on-line, or through the jobber you're buying your products from.
Old Feb 1, 2015 | 08:14 AM
  #55
WP50's Avatar
WP50
It been a project to get running and looking like I want, now I just want it white
Thanks WP
Old Feb 1, 2015 | 08:23 AM
  #56
WP50's Avatar
WP50
More good suggestions Thank you
WP
TUCCI
Powdercoat & Paint
Jul 7, 2014 10:35 PM
shuggy
Powdercoat & Paint
Apr 21, 2011 03:41 PM
gunner11
Jul 30, 2010 12:47 PM
goose246
Dec 6, 2009 07:10 AM
Shovelhead nick
Nov 24, 2009 10:00 AM
