1998 Flhrci Stator output?
Old Jan 31, 2015 | 12:48 PM
uplandpinter's Avatar
uplandpinter
Default 1998 Flhrci Stator output?
I have a 1998 flhrci and am working on a amp and speaker project. So I am thinking I mite want to up grade my stator output. I tried a search for the spects but was not able to find out what the output is on stock engine. Not sure If I even need to worry about this but thought I would ask.
Any ideas?
Thanks for your replies.
Brad
Old Jan 31, 2015 | 01:03 PM
Beemervet's Avatar
Beemervet
38 amp. Should handle an amp as long as it's not rediculously big.
Old Jan 31, 2015 | 01:47 PM
uplandpinter
Thanks for the reply. So I need to add up the draw on every thing like lights and such to see what the total draw is and as long as I stay under 38 amp I should be good to go correct?
Old Jan 31, 2015 | 02:12 PM
Beemervet's Avatar
Beemervet
I was sick the day they taught all the nuances of MC electric stuff. One of our experts will be along directly.
Old Jan 31, 2015 | 06:01 PM
Tee&Vee's Avatar
Tee&Vee
More or less that is the sum of it. Ask Dr Hess about his sporty. .. a stocker from the eighties came with a charging system that would stall if you braked too long with the high beams on. Lol
Old Feb 1, 2015 | 09:04 AM
Rob85WG's Avatar
Rob85WG
Don't forget that your battery also puts out a few hundred amps for short periods of time. If you have an efficient amp only the loud bass hits will draw a lot of amps.
Old Feb 1, 2015 | 11:44 AM
uplandpinter
Thanks for your responses. Boy it is starting to be a long winter already.
Only 180 days until I head to Sturgis!
Old Feb 1, 2015 | 02:46 PM
machinehed's Avatar
machinehed
Default amps. for the amp.
Any ideas?
Brad
The " stator " has one job and that is to keep the battery charged.
The elec. system runs off the battery .
Police bikes have a slightly higher output stator because of all the extra equipment like the radio , lights etc. running off the battery.
You should be fine with your original stator if your battery is high quality and high capacity.
Bike speakers are usually not very big so a 50 to 100 watt output amp. will do nicely. An amp this size is usually fused at approx. 10 amps. input current so your charging system probably wont even notice it.
What amp. and speaker combination are you interested in ?
ericl
Audio Systems
Sep 9, 2016 06:43 AM
olongapo1
Jun 16, 2013 05:23 AM
Benedetto
EVO
15
Sep 20, 2011 12:16 PM
fat bob bob
May 2, 2011 05:09 PM
hotrod351
EVO
May 1, 2007 01:38 PM
