Efi b gone
Old Apr 27, 2015 | 08:06 AM
flhchaz's Avatar
flhchaz
Default Efi b gone
I finally converted my '98 ultra from MM EFI to S&S Super E. Having a tough go at getting it timed. I know that for the ignition that I am using (Ultima 53-644) I need to get to top dead center on the compression stroke of the front cylinder. I am finding next to impossible to get to TDC by myself. Anyone have any tips on how to do this alone, or should I just buy another case of beer and call in some help to look in the timing hole while I spin the rear wheel?
Old Apr 27, 2015 | 08:25 AM
Owtlaw's Avatar
Owtlaw
I use a drinking straw in the spark plug hole as a visual guide. Verify the accuracy by the mark in the timing plug hole.
Old Apr 27, 2015 | 08:36 AM
flhchaz's Avatar
flhchaz
Thanks. I tried that and couldn't see the zip tie while laying on the floor turning the rear wheel, plus I cant tell if it is the compression stroke that way. Guess I'll buy the beer!!!!
Old Apr 27, 2015 | 10:11 AM
0maha's Avatar
0maha
Use the straw. Rotate the engine until you find the top of the front piston stroke.
Look in the timing inspection hole.
See the timing mark? You found it.
Don't see the timing mark? Rotate the engine so that the front piston goes down and then back up to the top of its stroke.
Look in the timing inspection hole again. You should see the mark this time.
If not, buy beer.
Old Apr 27, 2015 | 10:25 AM
flhchaz's Avatar
flhchaz
I think the mark will show on both the compression and exhaust stroke. I'll buy the beer, seems easier that crawling back and forth on the floor.
Old Apr 27, 2015 | 10:54 AM
0maha's Avatar
0maha
You are correct of course.
I'll now go have a cup of coffee.
Old Apr 27, 2015 | 05:36 PM
saz's Avatar
saz
Pull your pushrod tubes up, watch the straw and when it is at the top both lifters should be down. Look in the hole. You are TDC compression.
Old Apr 27, 2015 | 06:05 PM
flhchaz's Avatar
flhchaz
Thanks for the info. I understand totally, it's just hard to see the pushrods, straw, and the timing hole while I am turning the back wheel. I' got a buddy to help my tomorrow night, he can look in the hole, while I turn the wheel. No biggie.
Old Apr 29, 2015 | 05:54 AM
flhchaz's Avatar
flhchaz
SUCCESS! Had a friend come over last night and had it timed in less than 10 minutes. Now just gotta tune the S&S and will be all good to go.
Old Apr 29, 2015 | 07:15 AM
92Fatty's Avatar
92Fatty
Good deal.
Rusty Axle
Shovelhead
May 10, 2019 09:39 AM
lewk
Jun 30, 2017 02:32 PM
Ston
Shovelhead
Jun 7, 2017 06:32 AM
AmericanNightmare73
Ironhead
Feb 27, 2012 12:29 AM
Ovuel
Ironhead
27
May 11, 2010 04:07 PM
