Myth or Truth ???
Old May 8, 2015 | 11:35 PM
  #41
Ozark Joe's Avatar
Ozark Joe
Wow!! Your able to find them left and right but around here I've only seen them at dealerships. That is only once in awhile.
Old May 8, 2015 | 11:38 PM
  #42
Ozark Joe's Avatar
Ozark Joe
Originally Posted by texashillcountry
Ok but I thought you are only interested in a '97 or '98.
That is only 2 years.
That's cause the guy earlier in thread said about the frame change and the higher quantity of aftermarket parts with that change compared to 94-96. Ya'll convinced me otherwise though.
Old May 9, 2015 | 10:59 PM
  #43
ieatchickens's Avatar
ieatchickens
Calamity Joe,
I was in the same shoes as you a few years back. Wanted an evo Road King and was looking for a late model (97-98') with a carb.
Found my 96' with 40,000 miles and the infamous MM EFI and just couldn't pass it up. My plans are to dump the EFI and convert to carb when the MM EFI takes a dump. Problem is I've put 12,000 miles on the damn thing and the EFI just keeps working. I'm not trying to defend the reliability of the MM but they are not as unreliable I as was led to believe.
Talked to the previous owner and he never had problems with the EFI either. Then again, the motor is just about stock.
Some weakness with certain model years get really over blown with "forum hype".
Old May 10, 2015 | 10:11 AM
  #44
N-Truder's Avatar
N-Truder
Got a '92 Electra Glide here. Got it converted over to quick-release tour pac. Spent a small fortune on docking hardware for the TP and to add the passenger backrest. A lot of the newer stuff is minor changes. Went from fine thread to course on a lot of the bolts. Saddle bag struts switched holes on the weld-nut. Some spacers required for mounting docking hardware. Needed the console trim plate to hide the wires with seat change. Seats are a little bit of a kurfuffle but all of it was do-able.
Old May 10, 2015 | 12:52 PM
  #45
Big Dave's Avatar
Big Dave
Anythings doable with enough money and imagination
Check out Mikes Bike https://www.hdforums.com/forum/touri...ing-lives.html
Dave
icehead2
Jul 13, 2014 11:31 AM
El Fatboy 99
Feb 15, 2013 06:54 AM
fxesuperglide77
Ironhead
16
Sep 11, 2009 09:35 PM
BuckeyeFanInFL
Classic
May 8, 2007 12:30 AM
