Bike died no spark
Old May 29, 2015 | 09:15 AM
byronk's Avatar
byronk
Originally Posted by 1004ron
www.ultimaproducts.com/5361Instruct.pdf
http://www.google.com/url?sa=t&rct=j...93990622,d.b2w
Although 0.8 ohm on the primary side of the ign coil is not unusual, the Ultima manual says that it should be higher.
The secondary reading at 11,000 ohm is normal.
I'd be looking at the sensor that detects the timing.
https://www.hdforums.com/forum/evo-c...nd-info-4.html
I put a new rotor in with the new ignition module. This ignition has a switch that will allow it to run a single or dual fire coil and I have it set for dual. I think what I may do is go back to where I got the Ultra ignition module and get the coil and plug wires that go with it. This way i've upgraded my entire ignition and go from there since it seem that the ignition doesnt like the low ohms its seeing at the coil now.
Old May 29, 2015 | 09:17 AM
byronk's Avatar
byronk
Oh and thanks for the link. I read through the whole thread and it was very helpful.
Old May 29, 2015 | 08:39 PM
byronk's Avatar
byronk
Ok so I found a single fire coil here locally. Hooked everything up, static timed it and bam! fired instantly without even using the choke. Bike runs awesome! SOOOO much smoother, throttle response is like day and night difference from before. Thanks to everyone who posted up to help, you all are awesome. I have another thread here so i'll post results there as well incase anyone does a search.
RanHow
Ironhead
Sep 9, 2017 08:36 AM
tonycap
EVO
Apr 20, 2013 09:30 PM
Sledge
Nov 21, 2012 07:31 PM
nathanbedfordforrest
Ironhead
Aug 5, 2007 02:38 PM
steventh
Jan 1, 2007 04:58 PM
