Carb Issue
Old Sep 13, 2015 | 08:41 AM
bigjayree's Avatar
bigjayree
Stage IV
Default Carb Issue
I have purchased a 97 RoadKing with 25k miles. The problem is I get a Pop through the carb sometimes when shifting or from idle to pull out. My question is this normal for a carberated EVO? Bike runs great down the road and idles perfect.
Old Sep 13, 2015 | 08:57 AM
glidein wide's Avatar
glidein wide
Could be slightly learn or a minor intake leak via gasket or vacuum hose for voes if you're running one. It's a place to start.
Old Sep 13, 2015 | 09:37 AM
Racepres's Avatar
Racepres
That CV corb should be "the bomb" check for intake leaks first, as stated above..
Only re-jet/change the carb settings if that reveals absolutely that there is no Intake leak.
Then, generally removal of the "plug" at the low speed adjustment of the carb and a half a twist out should cure this.
Old Sep 13, 2015 | 10:33 AM
Hasher's Avatar
Hasher
Also, check the accelerator pump.
Old Sep 13, 2015 | 12:10 PM
br549A1's Avatar
br549A1
Default Carb Issue
I had to shim my needle one washer. If you have an adjustable needle move the clip down one. This was after rejetting I couldn't get rid of the cough and pop. One shim cleared me up. Something to try if your intake seals are good and everything else is correct
Old Sep 13, 2015 | 02:42 PM
Racepres's Avatar
Racepres
Even after unplugging the low speed and turning it out???
Old Sep 13, 2015 | 04:12 PM
br549A1's Avatar
br549A1
Default Carb Issue
Yes. CV Performance needle and it still needed a shim. I went through a lot of jetting changes new slide and diaphragm etc. it just needed a shim. Hasn't coughed since
Old Sep 13, 2015 | 04:15 PM
Spanners39's Avatar
Spanners39
If it's got the stock #42 idle jet in it will do that, go to a 45 or a 48 before pulling it apart and spending money.
Old Sep 14, 2015 | 04:05 PM
bigjayree's Avatar
bigjayree
Stage IV
Thanks guys!
joelorensen
Apr 23, 2014 09:07 AM
95custmz
Exhaust System Topics
May 9, 2013 11:43 AM
TXbobber
Oct 21, 2012 09:03 AM
beachrider
Dec 16, 2011 11:49 AM
greezymonkee
EVO
22
Oct 28, 2007 07:34 PM
