Bike sputtering/Bogs down feel
Old Feb 4, 2016 | 11:14 AM
bigpappa160's Avatar
bigpappa160
JohnnyC, I have a 91 Electra Glide Ultra Classic. The carb recal had to do withthe fuel needle and the hole it goes through. The sputtering/bogging down happened 1 time coming home from work, which the hill was pretty long, I'd say grade was 3-4 degrees. But what gets me is when I went to work that day I had to go up 2 hills and no problem. So I thought it had to do with the carb recall/ fuel needle. Had the carb recall done, no problem going home up hills. Had the fuel leak took it in they fixed that and coming home going up a hill sputtering/bogging down. I'm planning on going to see my mom and that same hill is on the way, so going that way to see if it does it again. But i'll check all fuel stuff plus coil, spark plug wires and spark plugs, which I tok them out back when I bought the bike and they actually need replacing which when I buy a used bike from a individual I usually change spark plugs.
Old Feb 4, 2016 | 03:01 PM
JohnnyC's Avatar
JohnnyC
91 is a CV carb. I'm not familiar with the fuel needle issue. I do know the float valve has been an issue especially with the ethanol in it. It eats away at the rubber hoses and the seats. Flakes of rubber would migrate to the carb and clog the Float valve which would often not seat and seal causing flooding. Often flooding can cause bogging down but you would notice a strong gas smell or dripping out the overflow.
Are you using a vacuum operated petcock which I think was stock for that year? Those can have issues especially if the vacuum line from the carb rots and breaks it's seal which also causes issue with the vacuum advance.
Being hill related leaves me with float adjustment. When they dropped the float bowl for the gasket they may have disturbed the float adjustment.
So many other electrical related issues from corroded connectors breaking connection but the vibration of the bike would cause intermittent operations interruptions more than just hills.
Try putting it on a ramp and see if you can cause the issue to repeat.
As odd as it sounds it might be time for a check of the intake seals. Sometimes age and sometimes doing anything that disturbs the carb like removing the air filter, which is a support for the carb, to do the other work can bring on that issue.
An easy test is to spray a little carb spray on the heads where the intake seals. This will cause a drop in idle when it sucks carb cleaner through a bad seal. It's not related to inclines but under a load while going up a hill any intake leak can cause issues.
BTW .... it doesn't sound like electrical or ignition related from the symptoms and recent repairs discussed.
Old Feb 4, 2016 | 05:53 PM
glidein wide's Avatar
glidein wide
Assuming you are running a voes,is it possible that the voes **** the bed or the vacuum line to it,causing it to be a dog climbing up a hill ??
Old Feb 11, 2016 | 12:40 PM
bigpappa160
JohnnyC the petcock is the one that has the on/off/reserve turn switch and the line from petcock goes straigh to the carb nothing in between. I am going to ride it to work in Morning, there are 2 significant hills on the way so I'll let ya'll know what it does or don't do.
Old Feb 12, 2016 | 01:32 PM
bigpappa160
Well a little update. Finally a chance to ride bike to work, which like I said before, going to work there are 2 significant hills, so went up first hill nothing rode smooth, went up second which was fairly long, still nothing, carried it's load doing 70 mph. This morning before going to work I was going to replace spark plug wires and spark plugs. Got out to bike uncovered it started looking around for the coil, well it up in front behind frame fork up under gas tank. so I didn't have time to get into taking seat off, taking bolt out of back of gas tank and loosening the front bolt in the gas tank to lift it up enough to get to the plug wires. Nothing simple about these EVO's but still love it.
Old Feb 16, 2016 | 08:38 AM
falconbrother's Avatar
falconbrother
When my 1988 did that I fooled with the carb and intake adnauseaum. I had the exact same issue, under throttle, uphill, 70 MPH, sputtering, bogging down. I replaced the coil and the VOES and it cleared up. Runs great now. Even starts on cold days. I feel pretty sure that it was a VOES issue but, I had a new coil so I replaced it while I was in there. The VOES came from Amazon.
Old Feb 19, 2016 | 01:47 PM
bigpappa160
Well, last update on this situation. Rode bike to work no sputters or bogging down going up hills going to work. Which I was going up the long hill about 70 gave it some throttle and it just keept climbing that hill smooth and fast. Thanks FOR ALL THE HELP
Old Feb 19, 2016 | 01:49 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Glad tho hear.... Ride safe...
Asuperglide
EVO
Sep 27, 2018 02:46 PM
Sithis
May 8, 2015 02:37 PM
suprchad
Nov 29, 2013 10:42 AM
beaverclever02
Jul 24, 2013 04:11 PM
richardhead84@yahoo.com
Sep 17, 2011 01:49 PM
