5 light dash panel
Old Feb 26, 2016 | 11:05 PM
jj471's Avatar
jj471
4th Gear
Angry 5 light dash panel
I have a 91 Heritage Softail Classic. I just purchased a 5 indicator light dash plate. It said instructions and wiring diagram included. Yeah right, so I called the manufacturer and vendor no help. Anyone one have these item to share.
Old Feb 27, 2016 | 12:47 AM
Prot's Avatar
Prot
Explain what you are trying to do.
Are you having difficulty with wiring, mounting, or what?
What kind of dash are you putting on?
This us what my stock one looks like.
Old Feb 27, 2016 | 06:49 AM
Tom84FXST's Avatar
Tom84FXST
http://www.officialharleyparts.com/wiring_diagrams.php
Old Feb 27, 2016 | 07:41 AM
jj471's Avatar
jj471
4th Gear
Yes mine is exactly as yours. Each bulb has 2 wires, a black and red. I assume black is ground. I'm wanting to know where red wire connections are made. I replacing my 2 bulb dash with a 5 bulb. Any help would be greatly appreciated.
Old Feb 27, 2016 | 07:42 AM
jj471's Avatar
jj471
4th Gear
I have wiring diagram
Old Feb 27, 2016 | 01:49 PM
Prot's Avatar
Prot
If your existing dash only has two bulbs that means it is aftermarket, not oem.
Post pictures of both.
Old Mar 2, 2016 | 05:28 PM
jj471's Avatar
jj471
4th Gear
New dash is all in thanks to a solder gun, test light and some heat shrinks. Wiring diagram in my service manual was a big help. Only thing is I wired the signal indicators where they only come on when signal is used. Thanks for the help.
Old Mar 2, 2016 | 05:49 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Great link Tom, bookmarked it. Thanx man....
edalfa
Shovelhead
Feb 16, 2019 05:30 AM
ratfinkharley
Electrical/Lighting/Alarm
Sep 3, 2018 02:19 PM
elk2112
Mar 1, 2011 11:07 PM
mpetrie610
Shovelhead
Mar 16, 2010 08:00 PM
jhill
Jun 28, 2009 11:45 AM
