Jinx Me
That off my chest.... I am happy about your clutch...
Like I said, this problem happened exactly four times over the course of about 5000 total miles of use.
Three of those times, it happened after running along at steady highway speed for 100+ miles. The fourth (and most recent) time, it happened on my way to work. Still at highway speed, but I had only been at speed for maybe five minutes.
That last time, I noticed that if I goosed the throttle sharply, it would fire up. That made me think what was going on was that somehow my float bowl was running dry, but there was still a bit of gas left in the accelerator pump. Shooting that gas in, and then having the engine spring back to life, caused me to eliminate anything ignition related as a root cause.
Since then, I've replaced the petcock and the fuel line. I've completely disassembled and thoroughly cleaned the carb. Replaced the needle valve. Replaced the float.
Like I said...so far, so good. The problem hasn't repeated.
WP
