1985 wide glide
Old May 8, 2016 | 02:33 AM
Hebrew Battle Rifle's Avatar
Hebrew Battle Rifle
I would forgo the relay. I have an 84 Softail and back when she was new I went through starter relays like breath mints. I finally solved the problem in a similar fashion as has been done to your bike. I eventually went to an open primary and kick start only because I got tired of dealing with those weak electrical parts. And I think that open primaries and points ignition are exceedingly cool.
Old May 8, 2016 | 05:49 AM
outfishin35's Avatar
outfishin35
Well the bike was converted over to a points as well...
Old May 8, 2016 | 02:37 PM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by outfishin35
Anyone know of a place where I could get a complete used wiring harness for and 1985 wide glide?
80's Harley wiring wasn't that great when it was new...don't think I would go through a lot of trouble to keep it stock. A lot of aftermarket company's make complete wiring systems that use modern connectors...all the wires are labeled, which makes for a really easy install...and you can pick up some modern features, like self canceling turn signals while you are at it.
I have wired several bikes with this one...works great.
Amazon.com: Ultima Plus Electronic Wiring System for Harley-Davidson (MW18-533): Automotive Amazon.com: Ultima Plus Electronic Wiring System for Harley-Davidson (MW18-533): Automotive
Old May 8, 2016 | 08:05 PM
outfishin35
Wiring diagram come with it?
Old May 8, 2016 | 10:29 PM
Tom84FXST's Avatar
Tom84FXST
http://www.ultimaproducts.com/18-533.pdf
Old May 22, 2016 | 07:40 PM
outfishin35
Tom84FXST,
Got that Ultima Wiring kit....Just a couple of questions. When wiring this kit up there is no need for the factory circuit breakers or flasher correct? Where's the best place to start? lol I'm figuring starting out with the handle bar controls and going from there...is there a better way?
Attached Thumbnails 1985 wide glide-20160522_151248.jpg   1985 wide glide-20160522_151329.jpg
misfitJason
EVO
22
Dec 23, 2018 10:52 AM
Sportsterbrett
Electrical/Lighting/Alarm
Oct 2, 2016 08:22 PM
SirEagle
Shovelhead
Oct 9, 2007 11:37 PM
81sturgis
Shovelhead
Jun 9, 2007 10:23 PM
yost44
Custom Models
Sep 16, 2006 11:10 PM
