Oil Pump
Old Jul 20, 2016 | 06:43 PM
prplglide's Avatar
prplglide
Originally Posted by Dr.Hess
Are you sure the new hoses are routed correctly?
I double checked with my service manual.
Old Jul 20, 2016 | 08:18 PM
Farm Shop's Avatar
Farm Shop
What caused you to think you weren't getting proper oil return?
One thing to keep in mind is that the scavenge (return) side of the oil pump is bigger than the feed side. So if you look at the return coming into the tank it won't always be a Nice steady stream. It can be kind of choppy and look like it is full of air bubbles.
Don't know if that helps but I'm just throwing it out there!
Old Jul 21, 2016 | 06:53 AM
prplglide's Avatar
prplglide
I did not know that, Farm.... thanx man!
The reason I figured oil wasn't returning to the tank is because I removed the line from the oil tank cover, removed the spark plugs, and spun the motor for a few seconds at a time and no oil was being pumped out of the line.
Now, I could be totally wrong here, but since the pump was pumping oil via the spin the motor with the starter method, I would have figured it would only be logical that oil would also return at some point as well.
Old Jul 21, 2016 | 07:10 AM
Farm Shop's Avatar
Farm Shop
Someone PLEASE stop me if I'm giving bad advice here.... But, it takes a second to get return after changing a filter because the filter is on the return side.
If you are confident the pump is primed and you have the lines routed correctly I would fire it and see what happens.
As long as you have oil pressure just give it a minute and see if the return comes
Old Jul 21, 2016 | 09:51 AM
Dr.Hess's Avatar
Dr.Hess
I would pull the plugs and crank it until the oil pressure light goes out. Then put the plugs in and start it.
Old Jul 21, 2016 | 10:40 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Old Jul 22, 2016 | 07:16 PM
prplglide's Avatar
prplglide
That was my plan. However, I wasn't sure there would be enough pressure supplied, by the low spinning pump, to have oil flowing back to the tank.
Old Jul 22, 2016 | 07:29 PM
Dr.Hess's Avatar
Dr.Hess
If the oil light goes out, there's pressure. Don't worry about oil going back to the tank. Either it will or it will puke out your breather, indicating another problem.
Why are you worrying about this?
Old Jul 23, 2016 | 05:02 AM
prplglide's Avatar
prplglide
I just figured that the oil had to complete its cycle, that's all. After all, if it came from the tank, it stands to reason that it should eventually make its was back, right?
Thelma
Panhead
Jun 16, 2017 08:48 AM
Wi_Duker
Apr 23, 2017 04:09 PM
Harley Bass
Ironhead
Mar 7, 2016 08:39 PM
jsbridgew
EVO
13
Sep 16, 2015 10:59 AM
pontojr
Oil Archive (no new posts)
Oct 21, 2005 11:03 AM
