Starting Problem - high pitched whine
Old Sep 2, 2016 | 06:50 AM
GREENOHAWK69's Avatar
GREENOHAWK69
Default Starting Problem - high pitched whine
Just started having a high pitched spinning noise when starting my bike the other day. Pressed the start button and bike was trying and made some noise and then a puff of black smoke came out of the a/c. Let go of the start button when thus happened. Pressed start button again and it started up.
Next day the high pitched spinning noise started, but the bike started. After work, tried starting it again and it "whined" a couple times (6x) before engaging and was able to ride home.
Looking for feedback as to what the problem might be. FYI - have not had chance to pull the primary cover to look at the starter area.
97 WG, newer (~ 4 years old / used ~ 2.5) All ***** Heavy Duty 1.6kw starter.
Old Sep 2, 2016 | 06:57 AM
touchdown's Avatar
touchdown
sounds like a starter problem, maybe bad Bendix spring. If it is the starter very EZ to replace, just pull it out and put the new one in. When you buy one get the better ones with more starting power.
Old Sep 2, 2016 | 07:01 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
^^This^^
FWIW I had an All ***** in mine but went back to OEM because it was always too noisy for me.
Old Sep 2, 2016 | 12:47 PM
GREENOHAWK69
The noise is due to the spinning and not engaging. Prior to this issue, it was fine. It is a heavy duty starter.
Any potential problem with the ring gear?
Old Sep 2, 2016 | 02:00 PM
texashillcountry
Dirt don't hurt
When there is a problem between the drive gear and the ring gear you will hear a loud crack not just spinning.
If you ever hear that noise it's best to fix it soon or it could go out on you at a burger joint in the middle of nowhere. (Damn that was annoying!!!!)
Your problem is in the starter itself.
Old Sep 2, 2016 | 03:07 PM
IBDAGRIZ's Avatar
IBDAGRIZ
Another possibility is the bolt for the jackshaft has come loose from the starter inside the primary.. Does what yours is doing also. Starter clutch would be next. Can be easily replaced instead of replacing the whole starter.
Griz
Old Sep 20, 2016 | 12:59 PM
GREENOHAWK69
Finally got a chance to look at the problem - pinion gear teeth are broken. Lots of "stuff" on the magnetic drain plug.
Attached Thumbnails Starting Problem - high pitched whine-2016-09-20-12.52.35.jpg   Starting Problem - high pitched whine-20160919_194858.jpg
Old Sep 20, 2016 | 01:29 PM
texashillcountry
Dirt don't hurt
Make sure the ring gear isn't damaged as well.
When mine did that I had damage on the starter drive gear and the ring gear that is on the clutch hub.
Instead of buying a clutch hub I installed a Rivera Primo 10/84 set and everything has been working fine since.
Old Sep 20, 2016 | 01:37 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Save Yourself a lot of aggravating and just replace the entire starter with pinion. It's 20 years old. and as stated check the ring gear. A 1.4kw is all you'll need....
Old Sep 20, 2016 | 08:06 PM
GREENOHAWK69
Entire starter set was replaced in 2010, due to the same issue.
