Quick primary/transmission inner race question
Old Sep 30, 2016 | 09:05 PM
Panheader's Avatar
Panheader
Default Quick primary/transmission inner race question
So I just pulled off my primary and noticed the inner race shifted inboard up against the trans output shaft...will this hurt anything or can I leave it?
Old Sep 30, 2016 | 09:06 PM
Panheader's Avatar
Panheader
Old Sep 30, 2016 | 09:53 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
It hasn't happened to me but as I understand it the race can walk in and take out the quad ring seal on the tranny.
Old Sep 30, 2016 | 10:06 PM
Panheader's Avatar
Panheader
I guess I should jut pull it and replace while im in there.
Old Sep 30, 2016 | 10:12 PM
texashillcountry
Dirt don't hurt
S&S makes a race that won't walk and Baker makes an inner primary bearing that doesn't use it at all.
If your gonna replace it I suggest one of the above instead of stock.
Old Oct 1, 2016 | 10:57 AM
thirsty's Avatar
thirsty
yes, i would replace it, as THC said 'could take out quad seal'.
mine did the same as yours. it then developed a small drip but i kept riding it that way, and it eventually caused damage to the 5th gear mainshaft.
Old Oct 1, 2016 | 08:24 PM
misfitJason's Avatar
misfitJason
I run the baker bearing on my dyna. It works. The s&s race works well too and then you can use a standard bearing
Old Oct 1, 2016 | 09:09 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Info: that seal is not the quad seal, it is the mainshaft/main drive gear seal.
The quad seal is in the transmission, inboard of the pulley spacer.
I would replace that race with the S&S part, it will not walk on the shaft.
Old Oct 1, 2016 | 09:34 PM
Panheader's Avatar
Panheader
Thanks fellas, I ordered the s&s race, I'll post up the removal process. Planning on the dremel/chisel method.
Old Oct 1, 2016 | 11:34 PM
texashillcountry
Dirt don't hurt
I'd be very careful of that one.
A friend of mine just had that done to his bike and it put a nice groove in his mainshaft.
When I had mine done the mechanic cut a couple of grooves in the sides of the race and used those to pull it off.
Another option is to get a hold of Mark at Baker and he can tell you how to get enough room behind that race to use the removal tool. (He posted it in another thread but I don't' remember where or how he said to do it.)
