Help with charging system
For ACV I selected 200. For DCV I selected 20. For ohms I used 200/))). I don't think I was taking my readings incorrectly, but I've been wrong before.
Bike is going to the Indy Monday.
http://www.cycleelectricinc.com/
I didn't know that they can provide up 29 amps.....
Spent part of the past three days doing the install. Did the test that was included with the kit to confirm it was charging and it passed perfectly.
Took two test rides and all seems normal again.
I do plan on replacing the battery and would appreciate any recommendations. HD batteries are about $150 I think and I see other batteries on line for less, but I am ignorant of the quality. What battery would you recommend?
Here's a pic of the fried stator and regulator I took off. I cut the plug off during removal for convenience. The insulation, as hopefully you can see, had burnt off exposing the bare wire. Had a bit of fun removing one of the small phillipshead plug retaining clip screws as the melted insulation found its way in the screws head preventing any grip for the screwdriver.
So that's that, and all is good in cosmoville. Thanks all for the help.
http://www.eastpennmanufacturing.com.../power-sports/
Griz
