Fork spring question
Old Dec 8, 2016 | 09:19 AM
Uncle G.'s Avatar
Uncle G.
Springs will collapse over time and not have the same rebound.
If you use the progressive set up you will have to use the spacer provided. They recommend 3" but i went with 3 1/2". love it...
As for the fork oil, you really should be replacing/changing as recommended @ 10k mile intervals. Sludge will build up and the dampers will not work as they should and will clunk. Always check the neck bearing fall away every 10k as well...
I change my fork oil and grease/check the head bearings at 5K intervals. I can't believe that new H-D touring bikes don't even have drain screws in the fork legs anymore (50K service intervals, I'm told-WTH!?!).
Old Dec 8, 2016 | 10:40 AM
grbrown's Avatar
grbrown
My 2011 Sporty doesn't have fork drain plugs either. Fortunately they are relatively easy to remove and strip.
titleist07
Sep 15, 2015 06:18 PM
spanky02
Sep 4, 2012 02:18 PM
dmbeveryday
Nov 15, 2010 09:21 PM
fstlane4me
Aug 12, 2008 08:53 PM
ROBSREDFORD
Jun 25, 2007 09:28 PM
