I have a 90 FXRS, while on a poker run last weekend I started off at a stop sign and it felt like I was holding the breaks, pulled off the side off road everything looked ok so I got back on started it up. when I put it into gear nothing. no movement at all. when I got it home I put it up on the stand put it into gear and I could turm the wheel with my hand, wheel would spin even in gear. also I can shift no noise and I can go from 1st or 2nd and back to neutral and the light comes on like eveything is normal, anyone got any ideas
thanx
Brad90FXRS
So what your are saying the rear wheel spins freely with the bike in gear?
If so I would think something happened in the primary, clutch or clutch basket, chain or the comp sprocket. Also check the front belt pulley.
