Starter relay?
Old Jul 15, 2017 | 09:50 PM
aces&8s's Avatar
aces&8s
Default Starter relay?
I usually replace the relay about every year or 2. For the past yr I have replaced it 3 times. What has changed to make it go out quicker?
Yes I have read the dreaded click thread.
Also is there a higher amp relay I can buy or better relay?
Old Jul 15, 2017 | 10:02 PM
FlamedFXR's Avatar
FlamedFXR
I think they are just made cheaper. I took one apart to see what was causing them to fail and the contact areas had a bad angle/fitment that causes the surfaces to arc and leave carbon deposits. Not much else it could be.
Old Jul 15, 2017 | 10:10 PM
aces&8s's Avatar
aces&8s
You could be exactly right since everything is from china now. Bet your right. Ill take apart my last one and check it out.
Old Jul 15, 2017 | 10:18 PM
aces&8s's Avatar
aces&8s
Took the OLD relay apart and it looks good. my next thought was my original starter is 21 yrs old... could have a dead spot in the starter and probably time for a new starter..
Old Jul 16, 2017 | 06:53 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Are you sure the relay is the problem, have you read out the circuit with a voltmeter?
The starter relay on my `89 Softail has been on the bike since `89...Although the starter solenoid has been rebuilt several times.
Old Jul 16, 2017 | 07:09 AM
Yankee Dog's Avatar
Yankee Dog
starter contacts are probably past their prime. See link as reference, your starter may vary:
http://www.yotarepair.com/startercontacts.html
Old Jul 16, 2017 | 08:46 AM
Beemervet's Avatar
Beemervet
It's that POS 111. Take it back out and I'll wring it out for ya.........
Old Jul 16, 2017 | 08:59 AM
WP50's Avatar
WP50
The starter draw of amps can whoop up on the relay.
Even so I would test it before going after a starter.
WP
Old Jul 16, 2017 | 09:20 AM
aces&8s's Avatar
aces&8s
I have not read the circuit yet but I looked at the contacts and one looks very worn. Now were getting somewhere. Thanks Dan.
Old Jul 16, 2017 | 09:24 AM
aces&8s's Avatar
aces&8s
Wish you lived closer, I would let ya take it for a spin. This 111 is addictive.
