Sprty gear slack feelin'
Old Sep 23, 2017 | 08:54 PM
Badluckbikes's Avatar
Badluckbikes
Default Sprty gear slack feelin'
Hello all, I have 2 questions that you could help me with. Sporty 94': Lowest derby cover screw housing is stripped. I figure the only thing I can do is tap it. So, should I tap it for a longer screw or a wider one?
The real question is, same bike, when I'm riding, mostly from a stop in first, the gears engage right away but after Ive let out the clutch leaver sometimes it feels like it disengages then engages again. It doesn't happen if I take it easy on the getting up to speed. I have checked the primary chain tension. Seems fine.
I hope I've made this clear. Thanks guys.
Old Sep 24, 2017 | 06:33 AM
flhchaz's Avatar
flhchaz
Drill and tap for the next wider screw. Check you clutch adjustment, sounds like it it slipping to me.
Old Sep 24, 2017 | 07:57 AM
Dr.Hess's Avatar
Dr.Hess
Yeah, sounds like the clutch is slipping. Probably time for a new clutch. And while you're in there for the new clutch, fix the hole with a Helicoil.
harleydeluxe09
May 27, 2016 03:09 PM
RidemyEVO
EVO
May 5, 2013 05:04 PM
TrooperM
Oct 24, 2012 12:50 PM
jmass
May 12, 2010 10:58 AM
bobbsterkid7
Aug 2, 2007 02:01 PM
