Yet another 80" build.
It seems like every year goes by it gets harder and harder to get a good tank of gas....
Pre 96 wiring wasn't great...but none of the blue chit in that pic came from the factory.
On the rear hole the piston is .020 above the deck with no gasket in place. The front measures .015 above the deck.
So I will have to get a set of .020 cometic steel base gaskets. Should i have .005 knocked off my front jug or am i splitting hairs here?
rear - 84cc .000 deck = static 9.84-1 corrected 9.07-1 ccc 188.2 .030 squish
figured with +12.9cc dome, .030 hg, +.010 bore, 40* intake close ABDC
with no compression releases, and 190 psi, heatsoaked, you'll be sneaking up on the start button
what I would probably do, that cam has some hefty TDC lift, check TDC valve to piston clearance, if there's room, deck heads to 81 cc's, install cr's, equalize deck heights,
static 10.21-1, corrected 9.40-1, ccc 195.9
cheap burrette to measure cc's
If i do the extra machining to get it closer to that 195-200 ccp mark wont i start having trouble finding good enough gas to make it happy? I wanted to stay a little on the conservative side because this is also my 2 up touring machine lol.
And Thanks for that link Schex. All the ones i was finding were around $100.
around 9.4 corrected compression is said to be the limit for 93 octane.
Your probably already checking this calc out, but just in case,
http://www.bigboyzheadporting.com/EVOComp.htm
I would look into compression releases though, hot start problems are no fun, big kickbacks, kill batteries and starters.
I saw what the machinist told you, I'd think it can be done.
I really would like to run compression releases, but my only option would probably be to box up my heads and ship them to hillside. Does anyone have pictures of where ther releases are located?
