Lifter Bleed Down
Old Mar 4, 2018 | 12:40 PM
glidein wide's Avatar
glidein wide
Default Lifter Bleed Down
So today I was in my push rod tubes and decided to spin the rod,just because,and it did not turn,only with a wrench I could spin it. Thought this was odd as my bike has not been started in three weeks. Front exhaust,the other three all spun by fingers.
Yes they are all adjustable and equal flats when adjusted last. What y'all think about that one not bleeding down ?
Old Mar 4, 2018 | 01:06 PM
Uncle G.'s Avatar
Uncle G.
Are you sure the lifter is on the base circle of the cam (valve is closed)? No matter where the cam is rotated, at least one valve will likely be open, at least partway. the fact that you can spin the other three pushrods says this is probably the case.
Remember, there isn't much travel in a lifter. If you're "parked" on a cam lobe, even if the lifter is fully "collapsed" the valve will still be held open by the cam.
Old Mar 4, 2018 | 03:28 PM
glidein wide
I'm sure it is parked on a lobe,but for some reason I was thinking it would spin easily after sitting for so long. Guess I forgot about the fact that the spring pressure is still on it and the valve is still opened and only bled to that point. I think I was having a brain fart.
Old Mar 4, 2018 | 03:50 PM
Ruggs59's Avatar
Ruggs59
Funny how sometimes little things send you into panic mode...
Old Mar 4, 2018 | 05:13 PM
Uncle G.'s Avatar
Uncle G.
That's the reason I inject some Marvel Mystery Oil into my cylinders before winter storage. To coat the cylinder walls to prevent any rust in case a valve is held open.
Old Mar 4, 2018 | 09:02 PM
WP50's Avatar
WP50
What Uncle G said
If it's really bugging you do the test mentioned with each cyl at top dead center on a compression stroke.
I'll bet your just fine
WP
Old Mar 5, 2018 | 05:03 PM
glidein wide
WP
No ,not bugging me at all,I should have known but I'm not getting younger and my brain needed to fart. I wasn't thinking,that will happen again btw.....
Old Mar 5, 2018 | 05:05 PM
Mattbastard's Avatar
Mattbastard
For what it's worth, there is never a crankshaft position where none of the pushrods are not under some kind of spring pressure.
Old Mar 5, 2018 | 05:33 PM
PlasdoSport's Avatar
PlasdoSport
that's a great idea! I'm assuming you squirt it through the spark plug holes? Would it be worthwhile to get some on the rocker assemblies too?
Old Mar 5, 2018 | 10:02 PM
Hey Man's Avatar
Hey Man
I never like to put Marvel Mystery oil anywhere near where it might find its way into the engine or trans oil. It's a penetrant and loves to seep into gaskets and every other nook and cranny to cause leaks in base gaskets, head gaskets "O" rings and seals.
johnod
EVO
Mar 11, 2017 05:19 PM
Mberlin74
Engine Mechanical Topics
14
Jun 30, 2016 10:07 AM
95ci springer
General Topics/Tech Tips
Mar 12, 2014 11:30 AM
magazine
EVO
Feb 28, 2013 08:33 AM
bikerlaw
EVO
Aug 25, 2010 11:33 AM
