1988 Clutch Problems
Old Apr 16, 2018 | 02:40 PM
Beemervet's Avatar
Beemervet
#9 Report Post
Old 04-13-2018, 04:13 PM
Eds01Eds01 is offline
New Member
I would bet that it's your throw out bearing!
You lose!
I have repaired that stud with JD Weld. Held for many miles.
Old Apr 16, 2018 | 03:07 PM
dtwaddell42's Avatar
dtwaddell42
6th Gear
Sure would be easier than trying to pull that hub off. I'm always a little nervous about JB welding parts that deep in the bike though.
Also would like to know what caused it to break. Unless I change something I would think its likely to just break again.
Old Apr 16, 2018 | 03:28 PM
nordhaven's Avatar
nordhaven
IMO if you can replace the part with new, then do it . JB weld is a hail Mary when no other options available. Just saying..
Old Apr 16, 2018 | 05:40 PM
bentparts's Avatar
bentparts
I was just about to list my clutch from my 1988 FLHS in the for sale section. Replaced with a later model when I went to a Baker Trans. It's got a new style reinforced hub, with the Zippers press on rear reinforcement for the back side too, SE plates and new bearing. Let me know if your interested. Mike
Old Apr 19, 2018 | 03:13 PM
daven9113's Avatar
daven9113
The aluminum clutch stand-offs are the weak part. Don't think you did anything wrong.
If you get the clutch hub puller, the job will be pretty easy.
You want a clutch hub with steel stand-offs: https://www.ebay.com/itm/V-FACTOR-73....c100005.m1851
You'll also need a clutch shell bearing, because it will more than likely be messed up when you press it out: https://www.ebay.com/itm/Eastern-Clu....c100005.m1851
thanoskazakos
Aug 11, 2018 08:48 AM
rick775472
Jul 5, 2015 09:08 PM
rdondes
Oct 23, 2013 08:16 PM
ChristoHD
Jul 4, 2012 10:15 AM
jerryw618
Jun 17, 2011 05:32 PM
