S&S HI-4N ignition
Old Jun 21, 2019 | 04:51 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Default S&S HI-4N ignition
I have one of those pieces of crap in my 111 due to warranty issues but I just wanted to tell anybody that was thinking about buying one...
DON'T DO IT!!!!!!!!!!!
The damn thing is worse than OEM stock ignition!!!
Old Jun 21, 2019 | 04:54 PM
RANGER73's Avatar
RANGER73
Mine is fine
Old Jun 21, 2019 | 05:15 PM
t150vej's Avatar
t150vej
Been running an Ultima 53-642 about 16k miles but no road trips yet. Consensus is they're dependable as any electronic gadget generally is. So far mines's been solid except for the pos coil that came with it. First hard rain and I was on the curb. Case separated from the face and was shorting out in all the water spray. I notice they're up to 53-644 now so I'm gonna put one of those or a Dyna 2ki in the saddle bag for roadside emergencies
Old Jun 21, 2019 | 05:45 PM
daven9113's Avatar
daven9113
Is it still working for you? What's wrong with it? Like to know.
Old Jun 21, 2019 | 05:49 PM
TwiZted Biker's Avatar
TwiZted Biker
I never liked the the H1-4 even when Crane made them, always found the timing curves a bit weird and they did no mix well with kick start bikes.
Old Jun 21, 2019 | 05:53 PM
texashillcountry
Dirt don't hurt
Cold starts are as bad as the OEM stuff and warm starts require me to hold open the throttle a bit to get the bike started.
Dynatek makes a much better ignition IMO and even though it voids the warranty I'm gonna pull the HI-4N and install a 2ki.
Old Jun 21, 2019 | 05:58 PM
TwiZted Biker
You'll be happier with the 2K, timing curves are much more user friendly.
Old Jun 21, 2019 | 06:13 PM
daven9113's Avatar
daven9113
Good to know. I thought it was heat issue being inside the cam cover. I don't think that you would void your warranty if you document that you changed the ignition correctly, etc.... Another way manufacturers want you to use their stuff. I not 100% sure though.
Old Jun 21, 2019 | 06:18 PM
texashillcountry
Dirt don't hurt
According to an S&S tech if I change the ignition module then I void the warranty.
Then again all I have to do is put the HI=4N back in if I have a problem!!!!
Old Jun 21, 2019 | 06:40 PM
daven9113's Avatar
daven9113
I did not read that. LOL..
Anyway, I did look up the S&S warranty for fun. First couple of paragraphs just says you have 12 months for anything to go wrong. Where they probably might get folks is no.1 on additional warranty provisions. I also looked up Ultima engine's warranty. They have lots more information, because they offer more long block sizes. Their warranty is very similar, except they allow aftermarket ignitions like Dyna along with their Ultima.
How's your S&S 111 working out for you?
