Help with a stalling problem
Old Oct 12, 2019 | 12:27 PM
  #81
splattttttt's Avatar
splattttttt
Not in tank
Only through the intake as it idles. And it can be a spray bottle set to stream not spray
as for the wire test to check for stalling
Had this issue with a 87 rice burner. And found it was the control module
Old Oct 20, 2019 | 07:36 AM
  #82
misfitJason's Avatar
misfitJason
New ignition ordered up. I went with a dyna 2ki, Daytona twin tech timing cup, and a new S&S coil that I had. The iggy should be here next week. We shall see if this is the key or not
Old Oct 20, 2019 | 01:25 PM
  #83
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
That probably wasn't the best choice.
The 111 is designed to fire at 30° BTDC and I don't know where the Daytona timing cup is set up for.
Old Oct 20, 2019 | 02:34 PM
  #84
misfitJason
Tex, I don't think the timing cup has any relation to the actual set timing. The cup is just the cup I believe. Nothing special. I could be wrong but that's how I understand it
Old Oct 20, 2019 | 04:13 PM
  #85
texashillcountry
Dirt don't hurt
The gaps in the cup tells your cam sensor when to send the signal to the ignition module that sends the fire signal to the coil.
The cup is keyed so that it will only go on in one position.
That makes sure your bike fires at the right time.
If you get a cup for a harley 80" motor the gaps will be set for 35° BTDC and like I said the cup that comes with the 111 is set for 30° BTDC.
Old Oct 20, 2019 | 04:49 PM
  #86
misfitJason
I got the cup that it recommends in the 111 manual by Harley part number
Old Oct 20, 2019 | 05:21 PM
  #87
texashillcountry
Dirt don't hurt
I didn't see one in the manual then again I never had to look.
Just out of curiosity what part number does S&S call for in the 111?
Old Oct 20, 2019 | 06:20 PM
  #88
misfitJason
I misspoke. It's the one that the Hi4n ignition instructions call for.
Old Oct 20, 2019 | 06:39 PM
  #89
texashillcountry
Dirt don't hurt
Attachment 600092
Interesting.
Not sure what that has to do with a 111 but it's interesting.
  #90
98hotrodfatboy's Avatar
98hotrodfatboy
It's not in the cup.. it's in the ignition itself.. You can set the base timing to what ever you want but it's always good to set to what's recommended...
