Rear brake seizing up
Old Sep 9, 2019 | 10:37 AM
Beemervet's Avatar
Beemervet
It does not matter what the brakes are doing/not doing, or what the cause is, a bike that has sat for a long time needs everything brake wise rebuilt/replaced.
Unless you depend on Flintstone brakes.
Old Sep 9, 2019 | 10:47 AM
hdvespa's Avatar
hdvespa
Replace the line. I had a similar problem with my 85 Flhtc a few years ago. The inside of the line is collapsing
Old Sep 9, 2019 | 11:08 AM
grbrown's Avatar
grbrown
Wink
I also agree that as you have a problem, strip and overhaul the entire system, inside and out, starting with the master cylinder. Remember also to clean and lubricate related parts, such as the pedal etc. I have had a rear master cylinder get so bad the interior cylinder bore was badly corroded, needing replacement, so check closely.
Old Sep 9, 2019 | 11:40 AM
bagga's Avatar
bagga
my 85 had that problem with the brakes dragging. there's a very small hole in the master cylinder that was plugged up. I had to remove the brass fittings to get to it. I blew it out with the compressor and everything has been fine since.
Old Sep 9, 2019 | 01:12 PM
RCermak's Avatar
RCermak
Default Rear brake
When the pads wear the piston will get stuck, happen to me in the rain on a gravel road they didn't look too bad. Rebuilt the master for good luck as well.
Old Sep 9, 2019 | 06:17 PM
mplecha's Avatar
mplecha
I have parts on the way. I'm going to rebuild all of it and go from there. This evening on my way home, I didn't even touch the rear brake, and it still seized. I had to vent the caliper twice in 15 miles. I should have the parts tomorrow. Hopefully, I'll have some time to work on it.
Old Sep 14, 2019 | 03:23 PM
mplecha's Avatar
mplecha
Just an update - I rebuilt the caliper and master, replaced the pads and put in a new hose and switch. All is good. Thanks!
Old Sep 14, 2019 | 04:14 PM
user 47363638's Avatar
user 47363638
I’ve always had problems with Harley rear brakes, I just got new ones instead of a rebuild. Glad your rebuild worked out for you.
Krugermeier
Feb 22, 2020 01:10 PM
CWS
Oct 24, 2015 12:15 PM
dirtbag1
EVO
Oct 22, 2013 09:41 AM
rphillips
Mar 9, 2013 03:53 PM
