Starter clicks but won’t turn over motor
Old Feb 17, 2020 | 05:31 PM
Steveareno's Avatar
Steveareno
Default Starter clicks but won’t turn over motor
So I put my bike back together yesterday. Went for a 60-70 mile ride. And I pulled off at a buddy’s house and bike wouldn’t start. The solinoid stuck out and that thing got hot! Cloud of smoke puffed out and everything. So I got it home. Me and the kid pulled the starter I took it to auto zone had them test it checked out good. Bought a new battery putt it all back together and same problem but the sollinoid will disengage. I pulled the plugs and same thing. It solinoid pops out engages the ring gear and bumps the motor but won’t turn over. I can look inside the cylinder and see the pistons try to come up but the stop. When I tried to start it yesterday day it came around like it always does but sounded like I picked up a rock and the motor sounded like it tried to crush it. The next time I hit the starter is when it tried to melt down. I’m really starting to think I may have sucked a valve. But I can’t see in the cylinder if there is anything in there. What do you guys think??
Old Feb 17, 2020 | 05:40 PM
joe40x's Avatar
joe40x
1st question is...
What are you working on? (Year/model)
Old Feb 17, 2020 | 05:53 PM
Jackie Paper's Avatar
Jackie Paper
Put it in gear with tire off ground and turn motor over with plugs out. (Ground wires) One thing at a time.
What exactly is put bike back together mean?
Old Feb 18, 2020 | 08:19 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Yeah, need more information as to what you put back together before all this occurred. Parts replaced etc... And year make and miles..
Old Feb 18, 2020 | 11:42 AM
Steveareno's Avatar
Steveareno
I figured it out. One of the screws from my carb walked out and went down the throat of my carburetor and into the head. So the piston came around and contacted to valve, or the bolt made it passed the valve and into the cylinder and is hitting the top of the piston and the head. Not a proud moment for me. It’s a 1995 flhtcu.
Old Feb 18, 2020 | 12:20 PM
98hotrodfatboy
Are you running an S&S E carburetor? If so you should be using blue loctite on the air horn bolts.. definitely gonna need a tear down. Post up some pics when torn down, of the combustion chamber and the top of the Pistons.. All repairable but the cost and downtime suck..
0maha's Avatar
0maha
Ouch.
Old Feb 18, 2020 | 01:15 PM
RANGER73's Avatar
RANGER73
Time for that Stage 3 you've been contemplating.
Old Feb 18, 2020 | 02:48 PM
daven9113's Avatar
daven9113
That totally blows!!
Old Feb 18, 2020 | 02:54 PM
TedMan's Avatar
TedMan
I like Vibra-tite Blue for these situations. Good luck with rebuild.
