84 FLHTC rear master cylinder
Old Mar 19, 2020 | 12:20 PM
Dante Staciokas's Avatar
Dante Staciokas
3rd Gear
Default 84 FLHTC rear master cylinder
This scooter has one of the lamest rear master cylinder set ups ever. Mounted under the frame with a remote reservoir. Nothing but problems with trying to keep pressure in the line - pads relax then eventually end up rubbing against the rotor, causing overheating and locking up.. Anybody have similar issues? I've rebuilt the master, same problems. Anyone ever modify or upgrade with a later model master? where it's mounted is just asking for dirt and grime to cause failure.
Old Mar 19, 2020 | 02:23 PM
bagga's Avatar
bagga
my 85 had similar problems. there's a very small hole in there that has to be open. mine was plugged . I got it open with some air pressure.
Old Mar 19, 2020 | 02:46 PM
Dante Staciokas
3rd Gear
Hey I appreciate the quick response!
Which hole are you referring to? On the master cylinder or the reservoir?
Old Mar 19, 2020 | 03:09 PM
bagga's Avatar
bagga
master. it's pin hole size.
Old Mar 19, 2020 | 03:16 PM
TwiZted Biker's Avatar
TwiZted Biker
Another tip for older bikes, pull the caliper up off the rotor and work the brake pedal till the pads come out enough to touch, watch the fluid level doesn't go low on you. This breaks the suction seal older systems will sometimes develop with the pucks sticking. Once they come together use a screwdriver to wedge them back open enough to remount, this also has the benefit of moving the brake fluid through the entire system in volume, helps displace blockages on mico ports.
Old Mar 19, 2020 | 03:32 PM
Dante Staciokas
3rd Gear
Thanks mate
bagga's Avatar
bagga
another thing I found was if the caliper pistons are corroded they wouldn't retract as they are suppose too. I changed the pistons two times on my 85 flhtc because they looked like this.
Old Mar 19, 2020 | 03:33 PM
Dante Staciokas
3rd Gear
Appreciate it. Thanks
Old Mar 19, 2020 | 03:35 PM
Dante Staciokas
3rd Gear
Yeah, am aware of that. Rebuilt a few over the years. This one is brand new but still wouldn't hurt to inspect. Thanks
juco
Ironhead
Aug 7, 2017 05:48 AM
JR-Boston
Jan 12, 2014 01:33 AM
SUUIE
Nov 13, 2012 02:30 PM
Jeff2002WS6
Aug 15, 2012 11:07 AM
ElectraRoadKing
Sep 25, 2010 11:12 PM
