I need help figuring out why my battery keeps draining? Anyone please help
Old Jun 4, 2020 | 06:24 AM
trippintrev's Avatar
trippintrev
Stage I
Default I need help figuring out why my battery keeps draining? Anyone please help
I have a 1999 fat boy softail that runs great but the battery has been dying quickly. I just bought a new one and its starting fine but I know its going.to keep happening. Any ideas on what it could be?
Old Jun 4, 2020 | 06:35 AM
Ben221's Avatar
Ben221
Did you test the old battery when you took it out? Do you have a multimeter? Trickle charger?
Look up testing a battery and parasitic draw on youtube and start there.
Old Jun 4, 2020 | 06:41 AM
touchdown's Avatar
touchdown
How do you know its going to keep happening? Could have been just a bad battery.
Old Jun 4, 2020 | 07:03 AM
mike131's Avatar
mike131
Old Jun 4, 2020 | 07:18 AM
0maha's Avatar
0maha
There is a sticky at the top of this forum with instructions for testing your charging system. Simple process. I'd start there.
Old Jun 4, 2020 | 07:34 AM
duoglider's Avatar
duoglider
how old was the old battery? If it's hit 3 yrs it will start deteriorating. How is the bike stored? inside? Outside? Heat will kill a battery faster than cold. Do you have anything that puts a constant, slow drain on the battery? Clock, etc?
variables come into play. But chances are the battery has just reached it's EOL.
Old Jun 4, 2020 | 08:03 AM
Architect's Avatar
Architect
If after testing you find the bike is not charging, likely just the voltage regulator. Good luck.
Old Jun 4, 2020 | 08:40 AM
nibroc's Avatar
nibroc
my 99 FLSTC does the same---I have to disconnect the VR every time I stop for any period of time...like overnite. I put up with it. My indies can't fix it---I'll keep subscribed to this..........
Old Jun 4, 2020 | 09:16 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Have you tried going through the sticky that Omaha mentioned?
Old Jun 4, 2020 | 09:48 AM
RLH3175's Avatar
RLH3175
On my 1996 I had a battery draining problem for a couple of years, if it sat for more than a couple of days, it had to go onto the battery tender, the battery was fairly new so I thought it couldn't be the battery. I finally bought a new battery, and no more problem with the battery. It sat all winter and still fired up with ease.
